Hi Guys,
I recently put a S1 R33 RB25DE in my R32 GTS25. Did manual conversion, brake upgrade, wheels, plugged in engine and she was running mint! Until we went to drive it.....has serious lack of power under throttle and "splutters" when you drive it. First thought was AFM or coils. Replaced both and still no change. Also replaced fuel pump and filter, checked O2 sensor, TPS and APP. Everything appears to be wired in correctly and no signs of any vacuum leaks. Im out of ideas! Any help would be much appreciated :-)
https://www.sau.com.au/forums/topic/413719-rb25de-conversion-problems/
so you just plugged it in with the existing harness ETC?
have you hooked up the alternator earth and all the other earth straps? forgetting those can have that sort of effect
if its the original harness, what did you do about VCT? just curious here.
Probably best for my partner to answer that one tonight lol. As far as i know he used the r33 loom and just wired in the r32 plugs where needed. I know he has hooked up the VCT and everything has been earthed (we double checked last night)
I was right, he has used the r33 loom with r32 plugs where needed, and has hooked up VCT. Plugging the VCT makes no difference to the problem either. Also eliminated any vacuum leaks. Partner is currently checking all the plugs he swapped over to r32 to make sure all the right wires are connected.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
