Up for sale i have my pride and joy
My R33GTST turbo coupe
Engine:
2.5 DOHC single turbo
Garret gt 35/40 high flowed roller bearing turbo
Spitfire coil packs
Big 3 core alloy radiator
Z32AFM
Big 300x600 FMIC
Custom intercooler piping 2.5inch
braided oil lines to and from turbo
188,000 Genuine k,s
Upgraded Dump Pip 2into 13inch
Highflow cat$$$$
Full Custom 3 inch stainless steel exhaust (Magnaflo) Cost nearly $2g
serviced every 10,000 using penrite 15-60Plus10 oil
Just had exhaust manifold gasket done and all turbo seals cost 700 for labour alone exhaust manifold gasket was sent over from japan and is full stainless that alone cost 260.
Major service just completed timing belt,water pump,fan belts, radiator hoses also fitted a brand new bosch 85AMP aternator,all vaccum hoses have all been redone heater hoses,manifold vaccum hoses ETC
Upgraded wastegate acturator
just had full compression test done brand new this car makes 162PSI per cyilder it is still curently making 159-161PSI per cyl so very healthy engine
new extreme brass button cutch with lightned fly wheel
Aircon regassed and is freezing
Suspension:
BC Racing race series fully adjustable coil overs done by pedders adjusted to legal height
HICAS lock bar
Brand new castor rod bushes in front
Body collar kit(alloy spaces that go into bushes to streghten and make handling better)
Factory wheels
Interior:
ADR approved sports steering whee fitted properly horn works
Calibre Boost gauge
SAAS 3 1/4 monster tacho
Front seats retrimmed in teal and black leather cost$950
Factory skyline matts in a1 Condition
Sony head unit(cd player)
Front spilts
Sony explode rear 6 1/2 200wat speakers
tinted windows re done 3 months ago front 15% rest 35%
interior is in immaculate condition with no stains on carpet or rips
Full electrics that work
Greddy H pattern stainless gear knob
SCA Alloy hand brake lever
Body: factory black 2 pac paint in VGC
Roof is a bit faded and has a minor dent in rear left quarter quoted 250$ to fix and repaint besides that body and paint is A!
Car has just had roadworthy done 1-11-2012 passed spot on not a fault picked
also had a pre check 28point safety check done by pedders on 16-10-2012 with full written report and they did not find a fault with it i have all receipts for most work done
This r33 has been dyno tuned and makes 219RWKW with 589NM Torque running E10 95Oct at 10PSI or 231RWKW@15PSI have dyno print out to prove which is also a copy in the photos on this add its a real sleeper and doesnt get any attention from police
Car will come with 3 months reg And RWC reason for sale is my girlfriend and i having a baby and not suited to us anymore is a genuine sale and i will be sad to see it go all the money is spent just get in and drive guy that dyno tuned it said it has been built for boost and would easily get up aroud the 270RWKW with a bit more boost does not burn any oil or leak any kind of fluids what so ever
Car has ran at heathcote park 12.8@101MPH
Way more to mention real sleeper car is Located in Bendigo Victoria if interested call or text anytime Carlo:0421 656 807
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
