Hey guys,
Parting out my GTR after the accident at lakeside. Have everything available except body panels really. I'll be stripping the parts off the car as they're needed so enquire within for prices etc.
Kgo
Car is being stored at mum n dads place in Jimboomba QLD so I can't grab photo's that often but hit me up if you want to see anything in particular.
Run down on what is in there anyway.
94 GTR
Unopened 26
-7 Turbos with actuators 20,000kms old $1000
550cc denso injectors $450
R34 GTR Dumps $250
Front pipe 68mm ID (i think) $350
Catco 3inch cat $100
Fujitsubo catback $150
NPC Organic Clutch pull type. <5000ks old $700
Turbosmart Boost tee $75
Nistune R32 GTR Ecu $300
Yellow Jacket Coilpacks $300
PWR Oil Cooler 22row? and trust oil relocator kit. Will need some hoses. Never fitted to car. $500
GTR Gearbox $500
Walbro fuel pump $100
GTR Seats good condition no tears or rips $600
Rear seats $?? Offer
Full interior available
Suspension available but will need to check what survived
Sumitomo calipers freshly rebuilt $350
RDA slotted fronts and Brakes direct rears brand new with QFM HPX pads $700
HEL Braided lines brand new $120
Diff, transfer case, hubs, axles, tailshaft etc all up for grabs cbf putting a price on it but you get the idea.
Have all of the stock parts for things that have been replaced ie stock suspension, stock turbos, stock injectors, coil packs, exhaust etc.
Willing to post at buyers expense. Have at it
:cheers:
https://www.sau.com.au/forums/topic/413747-r32-gtr-parts/
  • Replies 55
Sorry to see mate, what happened?
Interested in the PWR oil cooler.... send me a PM with your contact details please
Also, what suspension were you running? What are the wheels as well...
Cheers
https://www.sau.com.au/forums/topic/413747-r32-gtr-parts/#findComment-6626340
Looks like a pretty nasty crash. Hope you didn't suffer many injuries.
Which fujitsubo exhaust is it? What sort of damage did it take in the crash? MIght also consider that 3" catco cat if it bolts up to stock BNR32 front pipe.
Price on the tailshaft?
I'll need freight to Sydney for both.
https://www.sau.com.au/forums/topic/413747-r32-gtr-parts/#findComment-6628476
hey mate, how much damage does the side skirts have?
Side skirts have cracks, scratches and one is snapped in half. They are fibreglass so they can be repaired. $100 for the pair.
Hey mate im after the solenoid in the front steering rack its held on with 3 allen keys.
Sure $20?
what size is the exhaust ?
3.5 I think. Have 2 catback systems. Fujitsubo one and an Impul one. Both same size. Will post pictures later when I'm home.
Also got the car started on the weekend. No damage to the motor, started first go no problems and I've got a video of it running. After $3200 ono for the motor. It will come returned to stock unless deal done otherwise for -7 turbos etc. Throw me an offer on stuff and I'll see.
Stuff sold so far.
pwr cooler
brakes, lines and rotors
yellow jacket coils
strut braces
Cheers Colin.
https://www.sau.com.au/forums/topic/413747-r32-gtr-parts/#findComment-6640388
  • 1 month later...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
