So my understanding of this thread is that this fuel isn't recommended for non daily driven cars?
My cars lucky to be driven once a month sometimes, would this cause the fuel to go off?
If you ran 98 it could go off... I don't know how you got that information out of this thread.
Yes, there is a chance the fuel could absorb water, so make sure you don't stick the hose in the fuel tank. :P
There was mention of fuel absorbing water and rusting injectors in non daily cars so just clarifying
I think you must have read what I wrote. Toshi tuned my car and when I asked about E85 he said its no good for a weekender (or less). I'm just going off what he said to me; water absorb = more chance of knock & potential to rust injectors if the car sits. I don't know anyone who's had that problem and I'm not going to let it worry me at all.
I'm tuning on e85 later this year because everyone seems to love the extra knock protection, lower EGTs, Higher power and it's readily accessible for me so why not!
i odnt no about E85 going off - i asked the same thing and he said he has a rally car that lives at the work shop and comes out jumps on the dyno for a check every 6 months or so or before meets and the e85 levels never drop and is still running after 5+ years of competing - - thats his experience anyway - i have just been told not to let it sit in plastic containers
My customer used E85 and he did not drive 2weeks then his car start engine knock (He could not hear knock but his ecu is power fc so he can see how many knocks).
He refill E85 then stop engine knock.
I think fuel pump and injecter is not problem.
I've had zero issues. If the engine is knocking on ethanol something is very wrong, mine will cruise on 20:1 without ping. Going by the PFC for knock doesn't sound very accurate...
Unless it was a bad batch of ethanol? I usually buy from high turnover servo's but I have never had an issue with this either. (and I have filled many hundreds of times)
Depends where you buy your e85 from
I've heard of a few united servos now having bad batches of fuel where the e85 has dissolved everything in the servo tank coming out like rust water blocking pumps and injectors to the point where the car won run
Caltex eflex haven't had issues ever
Is that what you run micko?
Sounds like they never upgraded the tank at the servo then, which is very illegal. Caltex would have the same issue with the old steel tanks, but they were obviously a lot more proactive with their rollout.
Yes mate been on eflex for ages with zero issues :)
I was reading some yanky info on e85 the other day, and it mentioned that when installing fuel pumps in tank to insure that the terminals on the pumps and line had a non conductive cover or coating over them, because e85 is a conductive fuel and can short out in the tank and create fire.
Is that true I've never heard of anything like it before?
Exactly! Even if it did you got more power to drive away faster to extinguish flames :D
There is no oxygen in the tank, so no chance of a fire. Science! Anyway, my car exploding is of no concern to me if it goes faster :)
Lol. Mythbuster that shit. :P
The only way it becomes conductive afaik is when water is added. Probably best to just use the sealed Walbro 460L e85 pump to be safe.
I would think after 5 years on ethanol in my daily I would have dispelled most of the myths surrounding it, my car has not caught fire ever, the Walbro 255's are still running strong, and the fuel tank hasn't rusted away. I have also never cleaned the fuel filter... ;)
I am pretty sure there is oxygen present during installation of the pump.
I say plausible.
There will be air in the tank above the fuel but the vapour generally isn't as flammable in an enclosed space as people sometimes think .
The worry would be what was causing arcing across the electrical connections that may be exposed inside the fuel tank .
You'd think a pump drawing 18-20 amps would be more likely to do this than one drawing 8.6 amps .
    • Yeah I did, was a good one Also pretty sure Xona do mirror options
    • Me too, I wish they did v band reverse rotation - I'd order one straight away. Did you listen to the HPA interview with one of the Xona guys, quite interesting.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
