Hi,
I've just picked up a low K's 2010 GTR and am wondering what would be the best way to mount an extinguisher for CAMS events.
I'm sure there'd be a few on here that have mounted extinguishers somewhere on the passenger's side that could give some advice.
Thanks,
Phil.
https://www.sau.com.au/forums/topic/413760-extinguisher/
Not sure if they fit on the 35, but could give it a shot.
http://www.skylinesaustralia.com/forums/topic/376435-cams-approved-fire-extinguisher-bracket/page__view__findpost__p__6486230
Where are you located? If near me, you could test out my one before you order it.
https://www.sau.com.au/forums/topic/413760-extinguisher/#findComment-6626553
http://www.skylinesa...ost__p__6486230
Thanks mate. I'm SE of Brisbane.
That solution looks similar to what I didi with my GTE - home made bracket under the seat rails on the passenger side.
https://www.sau.com.au/forums/topic/413760-extinguisher/#findComment-6627670
Hi,
Thanks,
Phil.
Here is how I did mine....still allows for seat movement
https://www.sau.com.au/forums/topic/413760-extinguisher/#findComment-6629051
    • I’ve been considering one of these screens too, but I've heard mixed reviews about the software responsiveness. Some say it's great, while others mention lag issues. Before pulling the trigger, I'd check out a few recent user experiences to see if the latest models have improved.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
