Hey Guys
So I bought a set of splitfires to fix my jerking at WOT and misfiring problems on my RB25DET S2(R33 skyline)
May as well throw in a set of plugs while im at it...
Car has 3inch exhaust straight through with high flow cat. Nothing else.
Planning to raise the boost after I install a cooler and eventually shoot for 220rwkw(my daily driver)
What spark plug and gap would you guys reccommend (heard 0.8 is the best) ?
Ps: My apologies if this topic has been beaten to death , search function sucks. Thanks in advance for any help.
https://www.sau.com.au/forums/topic/413772-best-spark-plug-rb25det-220rwkw/
if you give it the beans on a regular basis, go the 7's, if you do a lot of driving around town, sitting in traffic and don't give it the beans very often, go with 6's. the 7's are a colder plug than the 6's, so they are a bit more prone to fouling.
my mechanic suggested platinum's instead of coppers. the BCPR7ES are copper i believe. any platinum suggestions?
any what gap should i run , engine is mostly stock as above
Edited by tripsteady
mechanic said the ones I currently have (IRIDIUM IX BKR5EIX-11) are not the right ones I need. Is this true(only done 3000km with them and the last to 100k)
only reason i want to change plugs is because im putting in splitfires anyway and wasnt sure if the IRIDIUM IX BKR5EIX-11 contributed to by backfiring problems
Actually, there is surprisingly little information about sparkplugs on this forum, I have found more useful threads on our UK counter parts. Most threads on this forum end with: "search there are plenty of threads asking this question" :). Mind you, this thread isn't on the right sub-forum so yeah off to a bad start.
Edited by Sarumatix
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
