Hi all,
Thinking of selling off my civic as I'm looking to buy a GTT, will use it for daily to replace civic hence getting rid of it. Just wondering if anyone is interested in buying this? It's stock standard (i have only changed the headlights + interior dome light), in fairly good nick though there are a few scratches here and there, very minor you'd have to be looking to see them. Car runs very well, obviously never thrashed (is that even possible?) safe and great daily drive.
PM me for more details and if you want more pictures and/or to talk about prices.
Located in Sydney, NSW.
https://www.sau.com.au/forums/topic/413785-nsw-eoi-civic-gli-1999-champagne/
bump, PM me for my mobile if you wish to enquire more (or just PM me your enquries)
Has 129XXXkm on it - 13y/o car so you can see that it's pretty low for an old daily!
Edited by darksky34
Ok. Thought I didn't really need to since it's just an EOI - but no problems.
Looking for $5500, but definitely willing to negotiate as there are a few things which may need fixing:
- both rear windows don't wind down well/at all but will go up fine (electric)
- some kind of belt/fan noise will get that checked out soon
- there is a scratch on the windscreen but literally unnoticeable
Basically nothing which affects the running of the car (apart from the belt/fan thingy which I will get fixed soon), so it's a great daily. Hit me up with offers.
    • Hi Apex and welcome!
    • Probably too late to reply to this, but worth a try. It's not calliper flex, the calliper as a whole is moving so it has to be calliper mounting bracket flex.  Calliper mounting brackets are designed to stop the calliper rotating, they don't need to be designed heavy duty to stop the calliper moving in and out.  Whatever it is is not the major cause of poor pedal feel, the outer pistons are moving towards the disc rotor the same amount as the inner pistons are moving away from the disc rotor.  Hence no change in fluid usage, what extra fluid is needed to move the outer pistons is recovered from the inner pistons. For a calliper to move as a whole by far the most common reason is the rotor is not perfectly centred in the calliper.  The first thing I check is that hub face is perfectly clean, bare metal, where the rotor hats contacts it.  Then I check the that rotor is firmly held in place by at least 3 wheel nuts (or equivalent). If all of the above are confirmed to be in perfect alignment then I would check the piston sizes and ensure that the 3 inner pistons and 3 outer pistons have matching diameters (eg; 28/32/36mm).  I have seen a no name 4 spot calliper that had 1 of the 4 pistons a different diameter. Maybe I missed it, are both the callipers exhibiting the same problem? I would remove the transfer pipe and inspect it to make sure that there are no restrictions. Maybe you already have but if not I would return them with the video and have them confirm all of the above.   Hope that helps Cheers Gary
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
