Alright so I've decided to finally make a thread about my current skyline(s) and keep a log of things I do and have planned for them. I didn't really make one before because I didn't have time to work on cars. But I'm getting up to exam period and soon and after it I'll be working close to full time hours so I'll have enough money and to get some work done.
First up is my main car, I love this thing:
Hi all this is my R32.
Completely standard genuine M-Spec. RB20DET, manual.
Only modifications were done by last owner which are Enkei RPF01 mags, Hicas lock bar and 3inch exhaust with sports mufflers. It even has a new catalytic converter rather than just replacing with a resonator. It's been cared for really well in its past life. Got a whole folder with receipts for work done by previous owners :)
I've recently replaced the fuel pump after it died on me on the way to uni.
List of things that need doing on it:
*wing mirror and rear spoiler have clear coat bubbles :(
*Clutch fluid leak somewhere, I think its slave cylinder
All fixed now!
*I've found that one of the rear bushes is completely shot and has leaked grease everywhere, so I'll need to drop the subframe and replace all bushes while I'm there.
*Rocker cover gasket oil leak, it was leaking slightly since I got it but it seems to have stopped now
*Fuel injectors are leaking slightly
*sort out the passenger door paint, it was hit by a motorcyclist and is a bit warped (you can see the black rust kill where last owner did a small fix).
I think lots of those issues are coming up because the car had only been driven less than a few thousand KM by the last owner over a year. So seals end up turning to sh*t etc.
The plan is to get this R32 ready for 4 and rotors in January so I can display it proudly next to the other guys in the club!
Pics of the car
I also bought a second R32 I figured since it was so cheap, I might as well get it and see what happens. I don't really have plans for it but I reckon a tidy up, fix what needs fixing and daily drive/sell might be in order to help fund my 20DET to completion.
It's a factory 20DE, auto. Drives awesomely and just needs a good clean up. I think this car will be mainly to practice cleaning and fixing bodywork techniques while my 20DET will be for engine and technical work. We'll see what happens :)
https://www.sau.com.au/forums/topic/413792-living-the-skylife/
Cheers Roy!
I probably will not put an FMIC on this one unless it's return flow and bolts straight in behind my bumper. I absolutely refuse to modify the body in an irreversible manner. Probably settle for a larger ARC side mount that I see pop up for sale sometimes on trademe.
I don't really have many modification plans for this, it's hard enough keeping up with maintenance while being on a student's budget!
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
