Alright so I've decided to finally make a thread about my current skyline(s) and keep a log of things I do and have planned for them. I didn't really make one before because I didn't have time to work on cars. But I'm getting up to exam period and soon and after it I'll be working close to full time hours so I'll have enough money and to get some work done.
First up is my main car, I love this thing:
Hi all this is my R32.
Completely standard genuine M-Spec. RB20DET, manual.
Only modifications were done by last owner which are Enkei RPF01 mags, Hicas lock bar and 3inch exhaust with sports mufflers. It even has a new catalytic converter rather than just replacing with a resonator. It's been cared for really well in its past life. Got a whole folder with receipts for work done by previous owners :)
I've recently replaced the fuel pump after it died on me on the way to uni.
List of things that need doing on it:
*wing mirror and rear spoiler have clear coat bubbles :(
*Clutch fluid leak somewhere, I think its slave cylinder
All fixed now!
*I've found that one of the rear bushes is completely shot and has leaked grease everywhere, so I'll need to drop the subframe and replace all bushes while I'm there.
*Rocker cover gasket oil leak, it was leaking slightly since I got it but it seems to have stopped now
*Fuel injectors are leaking slightly
*sort out the passenger door paint, it was hit by a motorcyclist and is a bit warped (you can see the black rust kill where last owner did a small fix).
I think lots of those issues are coming up because the car had only been driven less than a few thousand KM by the last owner over a year. So seals end up turning to sh*t etc.
The plan is to get this R32 ready for 4 and rotors in January so I can display it proudly next to the other guys in the club!
Pics of the car
I also bought a second R32 I figured since it was so cheap, I might as well get it and see what happens. I don't really have plans for it but I reckon a tidy up, fix what needs fixing and daily drive/sell might be in order to help fund my 20DET to completion.
It's a factory 20DE, auto. Drives awesomely and just needs a good clean up. I think this car will be mainly to practice cleaning and fixing bodywork techniques while my 20DET will be for engine and technical work. We'll see what happens :)
https://www.sau.com.au/forums/topic/413792-living-the-skylife/
Cheers Roy!
I probably will not put an FMIC on this one unless it's return flow and bolts straight in behind my bumper. I absolutely refuse to modify the body in an irreversible manner. Probably settle for a larger ARC side mount that I see pop up for sale sometimes on trademe.
I don't really have many modification plans for this, it's hard enough keeping up with maintenance while being on a student's budget!
    • If there's a next time, next exit after mine is Costco 😛
    • OK. But what about parts of the block that, when assembled, were twisted into a position that pushed into the void space, which, when disassembled, then released that force and opened back up, thus putting the grout into tension? Would effectively just pull the cast iron off the grout at the interface, leaving a tiny void and benefitting not much at all. Swings, and roundabouts. It's like putting something tiny into the fleshlight and finding out you needed a smaller one, to perhaps follow your area of expertise.
    • Nah. You buy a kit that has shorter tubes.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
