The 13 PSI that I run is only for the first 1500 RPM or so (to get the torque up) - it drops back to 11PSI quite quickly. Sustained high boost + high RPM is what makes these things crap out (well, aside from the usual culprits like oil starvation, foreign body colision, age, etc).
It's because of the way the turbine shaft is friction-fused to the ceramic exhaust wheel when they are made in the factory. They spin the shaft at INSANE speeds, and then press it into the centre of the ceramic exhaust wheel. The material then superheats and fuses together. You can actually load them up to 16+ PSI, but if you hold it there that's when they start to heat up, the friction-welds melt, and the exhaust wheel takes off down your dump pipe. You can run quite high boost through them and not shorten their life at all if you're smart about how you do it. As soon as you start towing heavy loads uphill, running it at the track or doing back-to-back drags runs, you'll heat them up and it'll come apart. It's quite interesting when they detach actually, because at high RPM and heat-load the welds will liquify, but it will still keep spinning and running happily. It's when you back off the throttle, and then load it up again (like during a gear change) that they shear off - I think because of the change in momentum experienced by the exhaust wheel.
  • Replies 47
I found the snorkel to be a restriction ages ago. The airbox on a GTR shouldn't be compared to one on a GTS-t or Stagea, which is where a lot of that information comes from.
I would also suggest that the turbine will shit itself in its own good time regardless of whether you are running 10psi or 12psi or 14psi. I am not arguing the science behind what makes them fail but history has shown that some fail with little or no provocation and some are flogged repeatedly and won't die. Regardless, on an RB25 there is little risk of engine damage (unlike a 26) so drive it till it fails.
With a decent filter and stock turbo it shouldn't be much of a restriction but you could have given it a single dyno pull without the filter element in to check.
I use a boxed pod but that was more for simplicity in making some other bits fit in. How much of a gain there is to be had (or not) I haven't measured.
Awesome stuff guys. LOL @ the first post - 26kg of aftermarket extras!
I'm planning to fit one of the JustJap stealth black intercoolers soon; I have a couple of questions I'd love if you could answer:
1. where can I get a kit for $400 (on their website they're $499) ? :)
2. do you need to reuse any of the intercooler piping from BELOW the chassis (eg. on the SMIC unit itself) as I think the bracket which bolts the stock pipes to the body, where it goes through the bottom of the engine bay, is attached to the original SMIC unit itself?
cheers!
DaveB
Hi Dave, see if i can get them all answered for you.
1. I got my kit second hand (but hadn't been used). You can often pick them up cheaper on ebay if you don't mind waiting for one to come up.
2. I re-used all of the standard hoses except one - pictured here bottom right:
Everything else got re-used. One of the standard intercooler hoses has a bracket attached to the hose and bolts to the body - this is the hose I didn't re-use.
Hope this helps mate!
I hacked up an old R33 airbox this afternoon.
Not sure if it'll make any difference, but at least it kept me out of trouble for an hour or so.
I left a bit of the snorkel tab there because that part is closest to the exhaust manifold & turbo. I know it's not much of a heat shield, but meh. At the end I gave it a once-over with some leftover matt black to hide all my dodgy cuts & scratches. It ain't pretty, but hopefully the dyno will tell me I haven't completely wasted my time.
Edited by joorsh
Cheers Joorsh! From memory that pipe is the only one which fits under the body... and of course eBay I will check... thanks :)
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
