Rb32 (450Rwkws) Quote From Garage7
MRHD66
 Share
here is the quote i got from Garage 7 to build a "reliable RB25/30 RB32 450rwkws"
still need coils and others little thinks too
parts price Nitto 3.2L stroker kit $6,500.00 Nitto RB series high volume oil pump $1,449.00 Oil restrictors $40.00 Moroso 1.5QT oil accumulator $295.00 Moroso oil accumulator mounting bracket 1 45.00 45.00 $45.00 Moroso inline electronic solenoid valve $155.00 Speedflow -10 AN 100 series braided hose (sold p/m)(100-10) 3 x $37 $111.00 Speedflow 1/2" NPT to -10AN male flare (816-10) $11.50 Speedflow -10AN male flare t piece x2 w/ x1 female -10AN swivel (145-10) $45.00 Speedflow straight -10 AN 100 series braided hose end (101-10)$20 x2 $40.00 ARP Nissan RB25 head stud kit $240.00 Permaseal MLSR head gasket $260.00 GARAGE 7 steampipe manifold $1,500.00 Plazmaman RB25 inlet plenum in silver powdercoat with 72mm TB $1,520.00 Camtech CTRB20 426A (a) camshafts - 272 adv duration/9mm lift $890.00 Camtech valve spring and titanium retainer kit $770.00 Ross Performance crank / cam trigger kit - includes Metal jacket balancer, crank trigger, cam trigger, x2 hall effect sensors, cam & crank sensor mounts $1,957.00 Powerflow blueprint 1000cc flow matched injectors w/CNC extrusions, plugs and adapters $660.00 Powerflow Nissan RB25 billet aluminium fuel rail $299.00 Powerflow 2 port high boost fuel pressure regulator (suitable for 900HP) $268.00 2.5L fuel surge tank $110.00 Holley 12-1400 dominator fuel pump (-10AN o-ring ports) 105gph @ 60 psi $399.00 Link G4 Xtreme ECU with A+B looms $1,750.00 SPR 3 bar map sensor $65.00 3 port boost solenoid valve $50.00 Garrett GTX3582R w/ 1.06 a/r turbine housing $2,500.00 Synapse 50mm external wastegate w/ flanges and clamps $450.00 Total $22,379.50
whats everyones thoughts oon the parts i got quoted
Edited by MRHD66
they'd be putting mark up on all the parts. Thats what you do when you own a business. If you did some shopping around yourself for parts, you could save some cash, but then some workshops might not like that.
so they are not even offering you any discounts on any parts after spending over 20k with them?!
if I was to get everything at once I'd get 10% that figure but that won't happen as I don't have a spare 20k just sittin there
yeh that's my thoughts exactly goin to use This as a guide and see if I can get these parts cheaper
straight away i can see things u can save some serious coin on, oil pump turbo fuel rail etc mabe try getting a similar quote from a few other work shops ? i know i got my motor built and it didnt cost no where near what i thought it would because i shopped for the parts and the workshop looked after me because we has spent so much there
cheers mate I will when i get some more cash
id get a t04z with a .82 rear housing and smaller cams and convert it to e85
I don't wanta convert to E85 with smaller cams will I still make 450rwkws on smaller cams with a gtx35 on pump 98 or 100
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
