here is the quote i got from Garage 7 to build a "reliable RB25/30 RB32 450rwkws"
still need coils and others little thinks too
parts price Nitto 3.2L stroker kit $6,500.00 Nitto RB series high volume oil pump $1,449.00 Oil restrictors $40.00 Moroso 1.5QT oil accumulator $295.00 Moroso oil accumulator mounting bracket 1 45.00 45.00 $45.00 Moroso inline electronic solenoid valve $155.00 Speedflow -10 AN 100 series braided hose (sold p/m)(100-10) 3 x $37 $111.00 Speedflow 1/2" NPT to -10AN male flare (816-10) $11.50 Speedflow -10AN male flare t piece x2 w/ x1 female -10AN swivel (145-10) $45.00 Speedflow straight -10 AN 100 series braided hose end (101-10)$20 x2 $40.00 ARP Nissan RB25 head stud kit $240.00 Permaseal MLSR head gasket $260.00 GARAGE 7 steampipe manifold $1,500.00 Plazmaman RB25 inlet plenum in silver powdercoat with 72mm TB $1,520.00 Camtech CTRB20 426A (a) camshafts - 272 adv duration/9mm lift $890.00 Camtech valve spring and titanium retainer kit $770.00 Ross Performance crank / cam trigger kit - includes Metal jacket balancer, crank trigger, cam trigger, x2 hall effect sensors, cam & crank sensor mounts $1,957.00 Powerflow blueprint 1000cc flow matched injectors w/CNC extrusions, plugs and adapters $660.00 Powerflow Nissan RB25 billet aluminium fuel rail $299.00 Powerflow 2 port high boost fuel pressure regulator (suitable for 900HP) $268.00 2.5L fuel surge tank $110.00 Holley 12-1400 dominator fuel pump (-10AN o-ring ports) 105gph @ 60 psi $399.00 Link G4 Xtreme ECU with A+B looms $1,750.00 SPR 3 bar map sensor $65.00 3 port boost solenoid valve $50.00 Garrett GTX3582R w/ 1.06 a/r turbine housing $2,500.00 Synapse 50mm external wastegate w/ flanges and clamps $450.00 Total $22,379.50
whats everyones thoughts oon the parts i got quoted
Edited by MRHD66
https://www.sau.com.au/forums/topic/413819-rb32-450rwkws-quote-from-garage7/
they'd be putting mark up on all the parts. Thats what you do when you own a business. If you did some shopping around yourself for parts, you could save some cash, but then some workshops might not like that.
so they are not even offering you any discounts on any parts after spending over 20k with them?!
if I was to get everything at once I'd get 10% that figure but that won't happen as I don't have a spare 20k just sittin there
yeh that's my thoughts exactly goin to use This as a guide and see if I can get these parts cheaper
straight away i can see things u can save some serious coin on, oil pump turbo fuel rail etc mabe try getting a similar quote from a few other work shops ? i know i got my motor built and it didnt cost no where near what i thought it would because i shopped for the parts and the workshop looked after me because we has spent so much there
cheers mate I will when i get some more cash
id get a t04z with a .82 rear housing and smaller cams and convert it to e85
I don't wanta convert to E85 with smaller cams will I still make 450rwkws on smaller cams with a gtx35 on pump 98 or 100
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
