Hey guys I am located on the Gold Coast, willing to post items at cost or pick up and currently have the following for sale;
R32 GTR (Will fit GTST) Aftermarket vented fibreglass bonnet, It is ADR approved and comes with approval documents, It has been fitted with bonnet pins but has the catch part and will work with r32 gtr standard bonnet catch system. The holes can easily be covered with a plate or filled in, or ready to run bonnet pins, can supply bonnet pins if req. It is professionally painted in jet black, no scratches painted underside aswell.
Bonnet$1000, Bonnet Pins $10, Bonnet hinges $40
R32 GTR Projector style Headlights L/H and R/H, also R32 GTR Indicators (All will fit GTST as well) All in perfect condition lenses mounts everything and comes with bulbs and rear covers etc.
Headlights $200pair Indicators $100pair (RH indicator has tiny crack, barely noticeable)
R32 Side Mirrors Black, R/h has slight damage as seen in pic, LH is undamaged $60
R32 GTR Passenger seat Immaculate condition, with rail, all movements working perfectly $300
Also have a std R32 Gtst drivers seat laying around in good condition for $50, and GTR rear seats in perfect condition for $120
Nismo Dash Cluster R32 GTR (320km/h and 10000rpm) (Will fit any R32) Immaculate condition with only just over 40000kms on it. $350
Momo steering wheel in perfect condition, also have an immaculate genuine horn button to fit. Steer wheel $150, Button $30
R32 Gtr Front strut Brace Avg Condition $120
Names Johnny I would rather you call or txt, otherwise please PM, avoid posting on the topic thanks
0414596256
More parts listed;
R32 GTR genuine Front Grill Very good condition $150
R32 GTR genuine front bar very good cond $300
R32 GTR genuine front lip $150
R32 gear and handbrake boots white with nismo imprint $50
R32 gtst A/C digital control unit $60
R32 GTR/Gtst centre console plastic surround $50
HKS intake kit for GTR with 3A racing pods only used for 2000km $200
Alloy 54mm radiator to suit R32 GTR/Gtst with silicone hoses only used for 2000km also have radiator brackets $200
Autometer Tacho with shift light $20 perfect working cond, with all brackets wiring req.
Plenty more bits and pieces from $20, adjustable arms etc stripping whole car including built rb26 with hks 2530's, PM or txt/call for further deets or other parts
Edited by slidinr32gtr
Gear and hand brake boots sold, as well as just the speedometer dial in the cluster, rest of cluster still for sale for $40, More Parts FOR SALE
Pwr FC hand controller $300
Power fc d-jetro map sensors and loom $300
Intercooler 600x300x100 $200 3" inlet/outlet big hks style tube and fin
3" cooler piping from twin turbo pipe to plenum $200 incl hose clamps and silicone joiners
Trust Type R BOV $300 stiff spring type
R32 REO $50
R32 Overflow bottle good cond $40
Door cards $60 pair
PM or txt for pics
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
