I would like to increase the strength of my power steering in my r32 coupe.
Anyone have any ideas on how I might do this? Anyone done this?
It would be nice to be able to more easily control the wheel with one hand while the other is on the shifter while course correcting etc. My daily lancer has great power steering!
https://www.sau.com.au/forums/topic/413860-r32-power-steering-modifications/
I've locked out the HICAS, looped the power steering lines to the rear solenoid which greatly improved the power steering feel, but was wondering if there was more I could do to improve the feel.
Or .. maybe I have an electrical problem .. any ideas on how to diagnose where the issue might be?
Out of all the cars I've owned or driven, my R32 GTR's powersteering is the lightest, infact so light I could control it with my thumb and index finger. There is definitely a problem with your PS.
List of things to check: Low fluid levels, slipping or missing PS belt, underdriven PS pulley, steering wheel taken off (aftermarket or standard) and not aligned dead centre when put back on etc
locking out the hicas wouldnt of made a difference except for maybe a placebo effect, i got my 32 with the hicas removed, i refitted it and the front steering felt no different
Thanks everyone for the responses
fluid levels are fine
PS belt is there, but squeaks sometimes
stock steering wheel - no mods
would getting a larger PS pulley (and overdriving it) damage anything at all?
Should I install a non-hicas PS pump instead?
Thanks everyone
Larger pulley will underdrive the pump.
Non HICAS pump only differs in not having a rear pump stage. I would try to find an R33 one anyway, just to get rid of the annoying loop. Oh, and fit a proper PS cooler in place of the original cooling loop.
But I wouldn't expect any of that to help your problem.
would running wide rims with stretched tyres cause the steering to be heavier? i.e. 9.5" all round? i have the hicas removed also and find the steering a tad heavy but then again i don't mind an extra workout and the steering feedback is always welcome I wouldn't describe it as light though compared to my MY11 Rexy
  • 10 months later...
old topic but incase anyone else is after the solition in the future.
the problem is the solenoid on the front steering rack. this is controlled by the hicas computer to make the steering really easy at low speed and a bit harder at hi speed 80km+ (when you wouldnt notice the harder steering) When people muck around with the hicas + the 32s getting old these days the hicas computer (located under the rear pacel shelf btw) tells the solenoid to make the steering harder by bypassing power steering flud in the rack sometimes when the car is below 80km which gives it a heavy feel, but not as heavy as no power steering, which is why people often get confused what the hell is going on.
the solution! take the solenoid off the front steering rack (3 bolts maybe?), trace the shape out on bit of metal plate, cut out the same shape and simply bolt on a metal plate in its place. Light power steering all the time!
  • Like 1
Does anyone have any photos of which solenoid needs to removed? Thanks! - also why would a metal plate need to be installed to replace said solenoid once removed?
Photos? Really? Open bonnet. Look at steering rack (follow steering column down under plenum). See solenoid. Has wires.
Plate is to stop the PS fluid pissing out when you remove the solenoid.
Mod is a bit unpleasant. R32 could use less assistance, not more. Would not do.
bit more info:
http://forum.r31skylineclub.com/index.php?topic=66472.0
gtsboy your power sterring is obiously working correctly. see so many 32 owners myself included winge about heavy power steering and this is the reason. trust me when the solenoid is active the steering is that hard to the point of believeing you have no power steering at all.
your right though... ghetto as mod
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
