Will pay $100 for standard ecu
(u pay postage to brisbane)
sounds good. whats your address so i can post it to you.
My account is with commonwealth bank
BSB Number:064447
account number: 1016 9705
account name: daniel paton
cheers mate
i wont be replying to any posts over the weekend. but if i can try and finalise as many sales as i can by next week i have the day off next friday so i can post all the stuff without having to lug half a car to work
Thanks
Have a good weekend
  • 3 weeks later...
  • 3 weeks later...
Hi,
How much do you want for the driver's side reverse light? I need to check mine I think it's the driver's side reverse light that has a scratch on it.
Is that the stock AFM attached to the Air box? Interested in the AFM. Are you willing to separate?
Also, do you have the clear cover for the instrument cluster? If so, what condition is it in?
dash cluster
dash cluster surround
glovebox
speedo - 72472Kms
steering column surround
passenger seat
rear seat
bracket covers for front seats - the bits that cover where the seats bolt down
steering wheel - original - good cond.
SOLD --> vents
Hi, how much for the dashcluster surround? Does it have the electric switches for the headlights and not just the knob?
Feel free to PM me if u want.
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
