Hey guys I have a lot of r32 parts for sale from various r32's I've owned in the past:
r32 projector headlights in excellent condition - $240
r32 clear type (genuine) indicators - $140
r32 seatbelts front and rear - $150 for the set or $80 for each pair
r32 non projector LHS headlight - $100
r32 speedo cable - $80
r32 speedo clusters 5 or so to choose from - $70 each
r32 cluster surround - $120 with all switches
r32 headlight switch - $50
r32 type m rear pods mint and in black - $100
r32 gtr/gts4 engine mount brackets (alloy) - $40
r32 gtr/gts4 stock rear suspension - $50 i think I have the fronts somewhere also which will fit a gtst
r32 gts (rb20de) stock air intake box - $150 not sure if it will fit a gtst
r32 stock dump pipe - $25
r32 stock front pipe - $25
r32 coupe bootlid holes for wing are welded up just needs a respray - $70
rb20/26det coilpacks working perfect - $130 will fit s1 r33 as well
rb20/26det igniter - $80
rb20det afm - $80 will fit r33 s1 as well
rb20/25 flywheel - $80
rb20det rocker covers - $70
rb20det tps - $40
rb20/25/26det cas - $80
rb20det timing belt covers - $60 for both
rb20det sandwich plate - $40
rb20det starter motor - $70
rb20det p/s pump - $80
rb20det injectors - $70
rb20det engine mount brackets - $60
rb20det knock sensor loom - $30
rb20/25 exhaust manifold - $50
rb20det stock intake manifold (bare) - $50
rb20det harmonic balancer - $70
rb20det cylinder head in good cond missing cams and cam caps - $150
rb20det block (bare) $50
rb20det cam gears - $30
rb20det throttle body - $30
rb20det manifold and turbo heat sheilds - $30 each
rb20det turbo oil and coolant lines - $60 for a set
rb25det turbo outlet elbow - $40
rb20det turbo outlet elbow - $30
I have more stuff around so if you need something feel free to ask
best to contact me on 0420 767 957 I can sms or email pics if required
also im located in qld 4115 and im happy to post pretty much anything (at buyers expense)
Cheers :)
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
