hey there i am chasing a rear wing for my stagea m35 also after any aftermarket parts people have i already have a HDI intercooler on its way so i will be after,exhaust,shocks,sway bars,boost controller,plenum spacer
https://www.sau.com.au/forums/topic/413930-wtb-stagea-m35-parts/
Ok here is some helpful info.
Exhaust -parraboi is selling his cat back so contact him.
Scotty nm35 makes turbo dump pipes
Boost controller - ebay mate or sau for sale section. I got hdi and works great and has duel stage.
Rear wing - good luck will have to come from japan. Contact jessestreeter
Shocks- www.justjap.com sell bc coilovers
Swaybars - contact daleo i believe
Www.importmonster.com.au (m35 search option) is a great site to get stuff from japan. There is also www.ebay.com.au (m35 stagea search option). Please use the search option as well. There is alot of useful info on here just take your time to search what you want
I have a second hand NUR with front pipe available for $850 not including delivery.....or spend the money and get a http://www.importmonster.com.au/view?url=http://page22.auctions.yahoo.co.jp/jp/auction/l131097130/&thumb=http://auctions.c.yimg.jp/f32batchimg.auctions.yahoo.co.jp/users/7/0/5/5/abm_japan_17-thumb-1340724274691680.jpg&title=R%20evo%20M35%20NM35%20VQ25DET%20790%2014933
Boost controller - Profec B II is the best atm.....HDI is good as well.....make ebay your friend.
Plenum Spacer contact iamhe77(Cam)
I might also suggest Scott's coolant Mod if your contacting him on the dump.
Good decision with the FMIC....work on getting the exhaust done next. Also drill out the banjo to about 2mm on the Oil feed for the turbo at the front of the motor and get yourself onto a grade 4 or 5 oil as soon as possible and you should get some good longevity on the turbo depending on how its been serviced in Japan and how much boost you run.
where are you located?
Thanks for the help guys
I am located in Bunbury Western Australia and I have only ran the car to get it licensed and took it straight to my workshop to begin the work I am in no rush and just want to get info on where others were getting parts from as i have used ebay but mainly stuff for c34s on there and have been searching the forums for a few hours and found some goodiees
mate im located in WA. ive sourced a few bits over here exhaust (not dump thats scotty :yes: ) brakes and sway bars. and done most of the work myself..
its good to see another western aus m35.
good luck
ohh axis, surely the first in WA :woot: ..
i go down to donnybrook to see family a bit, if you want should have a chat .. its a bit lonely for m35's over here pulled u to a champagne ARX a year ago and nothing since...
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
