That is screwed !! Dont reuse it
also it looks like your getting oil ring blow by on number 3
the head might be useable ? If the melted alloy comes out and no cracks or deep gouges that cant be sorted
hmm what about a resleve? i'm pretty sure it was a bolt down the spark hole that was the culprit but cant be sure engine dne 110,000km never started just cranked it over a few times. still think throw away? i think the head is fkd as the valve stem has snapped so the seat would be gone?
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
