Drift Vr Commodore
johnny boii
 Share
hey guys hopefully wont get hell shut down for saying any of this but im looking at making my 5 litre manual commodore into a drift car i have coilovers thick swaybars front and back 3.9 diff gears mini spooled diff im in the process at building the engine so it should have like 250hp atw but a shit load of torque just wondering if anyone has done it before and if they had any issues with it. i would be getting a hydraulic handbrake set up stripping the interior and 2 buckets and harness setup but the massive question is what kind of power am i looking at to make it through barbs also note i am a beginner haha only wanted to go commodore cause not many people have em and i have had this car years and love it. if anyone has any objections as to why i shouldnt also please tell me why haha :)
cheers in advance
jai
You've got the power and torque. You need to stiffen it up.... seriously. Suspension, sway bars, bushes. What you've got at the moment is good for starting, but if you want to advance you'll need to stop the excess movement.
We had a driver in the Drift series two years ago who did really well in his commo ute. He was making about 300RWHP but with a heap of torque.
As suggested, get the suspension setup nice and stiff and you will be fine with 250HP to start. We teach newbies at the back section of the track which is where you will be for your first outing. Come out to the track and well help give some advice on next mods to make.
Drifting is a lot about car setup but when starting out its all about getting time in the seat and learning!
nice cheers @optic i shall are you a teacher? i think ill just set my car up first and then come down be quicker to get it all done rather then doing it in bits hopefully dont get ripped on for a commo ahah i have a 33 aswell but to nice to drift ahha
Yeah mate, I started the training at the track a few years ago and still hang around to help out now.
I don't drift in Australia myself anymore and tend to leave that to trips to Japan.
Get it all setup and come out for a play as soon as you can :)
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
