selling my r34 skyline because i want to start saving for a house.
ive owned the car for 3years and have loved every bit of it.
took me a good 7months to find the skyline of my dreams so im not in any rush to sell.
the car has 131,xxxkms genuine on it.
the timing belt was done at 102,000kms by hills motorsports.
been serviced every 5,000kms by unique autosports and used liqui molley 10w - 40.
REGO 20-6-2013
money was well spent in the car no cheap bits only quality parts used.
engine
ive tryed to keep everything looking stock as possible so it doesnt atract attention even though i havnt even been pulled over in it the hole time ive had it.
- carbing cooling panel.
- blitz front mount intercooler returnflow.
- greddy oil cooler with thermostat sandwich plate.
- gt3076r garrett turbo with 3 inch midsteel dump pipe, low mount.
- 740cc nismo injectors.
- 355l/hr fuel pump
- z32 airflow meter
- iridium spark plugs (at 127,000kms)
- ProfecB spec 2 boost controller
- cushion button clutch (rear main seal changed when done)
- chromoly flywheel
- nistune ecu tuned by mrc at 275.2rwkws.
- 3inch engine pipe with hiflow cat , 3.5 inch Fujitsubo cat-back exhaust.
- greddy adjustable exhaust cam gear.
- i still have the stock intercooler , turbo , engine pipe, cat back , injectors, fuel pump.
interior
- Carbon fibre console an instrument surrounds (interior is immaculate).
- Aftermarket DEFI oil temp, water temp, boost guages with control panel.
- Nismo racing pedals.
- jvc dvd head unit, has usb and ipod connect and bluetooth, pioneer 6'9" rear, 6" front and split speakers with 4channel optional audio 600watt amp , 2x kenwood 12inch subs with a 1000watt kenwood mono amp (Aus radio frequency adapter fitted).
- saas racing seats. ( also still have stock seats).
- orginal skyline floor mats full set.
- boost controller panel.
- Optional traction control switch.
- hks turbo timer.
- A/C (climate control)
- changed dash lights to blue and have spare globes.
exterior
- nismo kit bodykit. ( with stock wing looks better)
- 19inch buddy club p1 racing plus 2 rims 275/30/19 kumho ku31s rear 245/35/19 front. about 80% tread.
- also have the stock 17inch rims with near new tyres 95% tread and 2 with about 50% tread,
- clear indcators.
- electric sunroof.
- carbon look pillars.
- dark window tint.
- Bilstein shocks.
- mu project brake pads.
$26,000
no low ballers thanks.
no joy riders.
as i dont want people thrashing the car and with no intention to buy,
i wont let you drive it unless you are basicly certain its the car for you.
post-76334-0-06452100-1353306991_thumb.jpgpost-76334-0-56622400-1353307013_thumb.jpgpost-76334-0-42576300-1353307026_thumb.jpgpost-76334-0-74193700-1353307089_thumb.jpgpost-76334-0-71629700-1353307113_thumb.jpgpost-76334-0-52140100-1353307252_thumb.jpgpost-76334-0-20243700-1353307270_thumb.jpg
https://www.sau.com.au/forums/topic/413989-yellow-r34-gt-t-1998-275rwkw/
im offering you all the stock parts included in the price.
looking around at other cars on carsales not many have sunroofs or even bodykits below 18k.
and cars that are higher then 18k have the power but lack in other factors.
ive spent well over 15k on the engine mods alone to have it at a safe tune and boost lvl with good power and i know ill be selling it at a loss as it is.
i would consider seling for lesser value without the stock parts.
without the
-stock rims with tyres
-stock turbo
-stock intercooler
-stock seats
-stock injectors
-stock fuel pump
-stock indicators
-stock cam gear
-stock exhaust from turbo to catback
i would take $24500
some more photos.
and a bought and history check so you dont have to .
you can check anyways doesnt worry me cost 18bucks always reconmend doing one incase seen alot of cars that have came back write offs.
car also has an air horn fitted to it thats what the switch is near the turbo timer
alright thanks for all the info. just noticed your car is registered as a sedan?
good luck selling it.
For your information go do a check on all the coupes and see what they are.
All the coupes are registered as sedans I checked with the rta and it doesn't matter because I thought it was an issue
surely RWC is covered at that PRICE! Also can you provide a break down of what costs $15K, as I only just did a quick estimate of around $8K for the engine mods??
Thanks
I'm at work I have the my receipts at home.
Part of that would also be labour cost.
I don't feel I should have to explain every little thing to people that aren't even interested in the car.
I don't need to sell the car so if everyone thinks it's to high I'll keep it doesn't bother me.
Thanks for answering my questions, it's not that I'm not interested because I AM looking for a GTT, yet I'm asking all these questions mainly because I'm very curious as to why it's priced as it is (though I can guess - and I was right). Having said that, it's way too expensive for me. So no problems!
Thanks
Ok no worries, good luck with your search
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
