Hi guys,
I've got a s2 r33 gts-t with a wheel scrubbing issue up front.
Components wise here's what I've got on there:
18 x 9.5 +38 with 15mm bolt on spacers (think this makes it effectively +23?)
Sydneykid bilstein/whiteline coilovers
245 wide tyres
Guards rolled
The scrubbing occurs when I hit a big bump, when I transition a lot of weight onto one wheel (high speed cornering) or say if I'm going downhill and turn hard and transition onto one side etc. I think from looking at the markings on the guards, that the main issue is because this wheel and tyre combo edge sits in line with the outer guard edge, so there's not a lot of travel distance needed to make contact and relatively soft suspension. Here are some pics of where the wheel sits and the markings:
I have thought about doing
Stiffer coilovers
Front camber arms/bush kit
Try fit thinner tyres on same rims
Thinner rims/thinner tyres
Is it possible with some combination of neg camber and smaller width tyres to fix this, or will I need to go to a smaller rim & tyre combo only?
Ideally I'd have an 18 x 8.5 +30 on there without the spacers, but this is the most expensive option, so I thought I'd ask some experts on here first if it's possible to work with what I have.
Cheers.
Edited by copycutter
I've got 18x9.5 +20 with a 235 tyre and lowered on my 33. I have fairly stiff suspension and no rubbing what so ever in hard high speed cornering and all. Maybe try and get the guards lipped and it might give u more clearance. It's fairly cheap. Maybe 50 a corner
Ditch the spacer, or you can go camber arms and add some negative camber (doesnt look like ur running much camber at all), just depends how much camber would be required, looks like 2.5-3 degrees may do the trick and isn't too crazy? Or lastly the most expensive option of thinner rims. My advice is ditch the spacers if possible (or get thinner spacers)
His guards are already rolled
lose the 15mm spacers, looks like theres 15mm odd of rim sticking out, just see how well the rim clears the suspension arms etc, on the inside of the arch
hahaha We msg'ed at the same time, The only option left is different rim with smaller offset.
What size are your brakes? how do 18" not clear the brakes?
Edited by badben
They're just stock brakes, but for some reason the +38's spokes design on the CR Kai means the spokes hit the edge of the brake caliper. I've tried 5mm slip ons - still fouls. It's just the shallow design that comes with that offset. I've got 9.5 +20's on the rear and I had to initially run them up front until I got the front spacers, and they cleared easily. I've never seen bolt on spacers in 7-8mm and I'm not real keen on slip ons, especially over 5mm.
The answer is as simple as it always has been.
Only use wheels that SUIT ALL ASPECTS OF THE FITMENT. That includes brake clearance.
No point having pretty wheels that make the little girls' pants fall off if you have to fit stupid spacers to make them work.
Depends on spoke design as we'll as offset. You will need to test fit the rims unless someone else on here has run those exact rims on there r33 and can advise. Cheap option, camber arms. Expensive option different rims
Going off your pic's, your car has good clearance around tyres, maybe suspensions to soft. Allowing to much travel.
Just so you know camber arms will make your tyres wear unevenly so you'll need to do regular tyre swaps, Front to back , left to right depending on if your tyres are directional or asymmetrical
Your guards don't look very rolled to me. Lose the inner splash guards. Failing that, I have posted this before. Works great, and it's free, just take your time.
http://www.skylinesaustralia.com/forums/topic/401848-trying-to-fit-my-dream-wheels-te37/page__st__20
yeah guard doesn't look very rolled to me at all
judging by where that scubbing mark is on whatever corner that under guard pic was taken you'd have no problem if they were rolled properly
also looks like you could do with dialing in some negative camber
Edited by mystery_kid
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
