Selling all the NEO parts i have that i no longer need.
Located in SA. Postage at buyers expense. PM me.
NEO / R34 RB26 CAS - $100
NEO Coil Pack Loom, Good condition - $80
NEO Coil Packs, 40,000kms, Good condition - $200
S2 RB25 Throttle body (clean) - $50
NEO Plenum, bare, sand blasted - $60
NEO Injector Loom - $60
NEO IAC Block, sand blasted - $70
NEO Trac Control Throttle body - $60
S2 RB25 / NEO AFM - $100
NEO Injectors, Been in plastic bag since removed from engine - $100
NEO Boost Sensor - $100
NEO Engine cover - $50
Brand New NEO Harmonic Balancer - $280 ($340 new from KMS)
Brand New Clutch Fan Suit RB's - $170
NEO Water Hoses (Brand New) - Doesn't Include All but a lot of them - $160 (Were $250 odd from Nissan)
- Front bleed valve to thermostat housing - 14056-AA500
- Rear bleed valve to rear block t piece - 14056-AA510
- Rear bleed valve to throttle body - 14056-AA505
- Rear bleed valve to runners - 14056-AA515
- Front bleed valve to runners - 14056-AA520
Tomei INLET Adjustable timing gear - $150 Including postage.
NEO Pistons and Rods - $100 good nic - Rods are the same as RB26 rods
https://www.sau.com.au/forums/topic/414069-rb25-neo-parts-for-sale/
Have you worked out if you need it?
Sorry for the late reply. I honestly havn't worked it out if i need it or not.
Do you know the precise reason for it? I know it controls the valve for the purge canister. But why did the NEO have this ECU controlled solenoid valve and all other RB's did not?
Bump btw.
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
