THIS IS MY 1991 R32 GTR FOR SALE.
ONLY 57000 ON THE CLOCK
IMPORTED IN 2006
6 MONTHS REGO
ROADWORTHY WITH SALE
CAR IS IN A1 CONDITION INSIDE AND OUT
ENGINE WAS REBUILT 30000 AGO, COMP TEST TO PROVE IT
N1 TURBOS WITH BRAND NEW DRIFT POD FILTERS
TOMEI FUEL PRESSURE REG WITH WALBRO INTANK PUMP
FLASHED ECU WITH A DYNO TUNE
3'' TURBO BACK EXHAUST SYSTEM WITH HI-FLOW MUFFLER AND CANNON
BRAND NEW HD EXEDY CLUTCH,REAR MAIN SEAL,SPIGOT BUSH AND SLAVE CYLINDER
TURBO SMART BOV
ELECTRONIC BOOST CONTROLER STAGE 1 AND 2
BLITZ TURBO TIMER
BLITZ BOOST GAUGE
SPITFIRE COIL PACKS
NISMO CATCH CAN
CARBON FIBER STRUT BRAC
ENGINE DAMPNER
ADJUSTABLE SHOCKS ALL ROUND
DBA4000 ROTORS ALL ROUND
RAYS 17-9 WITH NEW NITO SEMI SLICKS ALL ROUND
BRAND NEW OIL IN THE FRONT AND REAR DIFF,TRANSFER CASE,GEAR BOX AND ENGINE OIL AND FILTER
KEY LESS ENTRY WITH IMMOBILIZER
BRAND NEW BATTERY
NISMO DASH
KENWOOD DVD PLAYER WITH SPLITS IN THE FRONT AND REAR WITH A 2 CHANNEL AMP
A/C IS COLD AS AND WORKS PERFECT
WINDOWS TINTED
FIRST TO SEE WILL BUY, THIS CAR IS PERFECT INSIDE AND OUT AND DRIVES LIKE A NEW CAR
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
    • Now that these are NLA, I suspect the answer is going to be to 3D print the plastic bit and glue on some felt or something to replace the brush. I have one or two of them (new) in the shed to go onto the car at some point. I could put some effort into measuring them up and could attempt to draw up the printed part in FreeCAD, if there is interest.
    • Hey team, the R32 ones look different to the R33 and 200SX ones. Also they're sold out on Amayama, looks like some dealer cleaned up the stock.
    • Might have to @Dose Pipe Sutututu him
