Coilpacks
R33huntme
 Share
So im thinking about upgrading my coilpacks and want to know what the options are,i see a lot of people are going for the spitfire coils $600 but i found that n*power do a set for half the price $250 delivered anyone know what these are like or anyother one that are good but cheap ish
i have a 1999 nissan stagea 260rs running 349kw @the wheels
Edited by R33huntme
Splitfires or possibly Yellowjackets but none of the rest has a track record.
Or look at getting some of these (my next coils):
http://www.aemelectr...smart-coil-1240
or with the price of freight fom the US these days may be cheaper to buy them from NZ
http://www.trademe.c...n-535557442.htm
or direct from their website:
http://www.nzefi.com/products/
my yellow jackets started breaking down pretty badly after 18 months.
decided to spend the extra and have some okada projects plasma direct coils now, so far so good
http://www.okadaprojects.com/
Did you get them from the US or Japan (I believe they are made in the US)?
Do they plug straight in or do you have to use leads?
And what was the cost for 6?
Okada projects will be at least $1600. I was looking at them till i seen the price. Now im looking at MSD LS2 coils.
Have you had a look at these Ray? I will be getting some next year:
or available from NZ (maybe cheaper freight than from US these days) c/w mounting bracket (still need to make loom and get leads):
http://www.trademe.co.nz/motors/car-parts-accessories/performance/electronics/auction-535557442.htm
or from their website
payed around $1000 for the 6 so quite a bit more expensive than most of the other alternatives,
yes they plug straight in
i beleive they came out of japan, i got them from here http://www.hioctanedirect.com/index.php?main_page=index&cPath=25&zenid=kg6vv9nv4it167qe4h7cnsoce7
Cool so are you back to 1.1mm spark plug gap now?
Prob wouldnt work out cheaper after the freight. Besides LS2 coils are more readily available.
Wow they have come down alot since i priced them out of japan.
also had the same dilemma. just bit the bullet and went splitfires.
difference is amazing , but i guess any coils would show that vast difference compared to the 15 year old coilpacks.
in anycase , yellow jackets have been shown to fail some of the time as well , much less then splitfires do.
i would suggest splitfires, dont touch the $250 cheap coils....
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
