I am currently stripping my car as I have no licence and lost all interest in imports, here is the engine
Rb26DETT Build and inclusions as follows;
Run in and was tuned to 14psi has done 2000km, made almost 400HP at @ 14 PSI
Mild Port polished head fully reco'd replaced all retainers
Tomei 1.2mm headgasket
Genuine nissan gaskets used throughout rest of build
Tomei Oil restricter in block
Gold painted cam covers
Sard 700cc injectors
Fitted with D-Jetro map sensor nipples can be blocked if not using
Oil drain fitting at rear of head, braided line to sump
All new silicone heater hoses and vacuum lines
Polished Plenum and twin turbo pipe
Water Pump was replaced as well as T/Belt tensioners etc at build
Block decked and machined, bored and honed for 20 thou oversize pistons
Build Blueprinted and all measurements adhered to
Eagle forged rods
CP forged Pistons 20 thou
R34 GTR crankshaft
ACL RACE series bearings
ARP Headstuds
Jun Sump baffle with steel trap doors
All new brass Welsh plugs, block painted in black enamel
Motor included all listed minus parts below $6500 (Whole motor plus intake side minus turbos and accessories)
Here are the extras add prices if wanted with package, currently it is all together still
HKS 2530's brand new when fitted to motor $2000 (Still on engine, if separate sale extra for fittings etc)
Nismo Engine Mounts also new at fitment $100
R32 GTR engine loom complete for $250
Have alternator and Pwr steer pump plus belts for $80 a set
Splitfire coil packs and loom for $450
Feel free to PM txt or call if you would like to mix and match or if you want a cheaper price i can for example change injectors to std etc, I have heaps of other parts for sale as I am stripping my car so dont hesistate to ask. Can also organise fitment of any other parts you may have or want to purchase towards your setup, I am a trade certified mechanic.
Johnny 0414596256 Gold Coast (North)
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
