Tomei Rb26 Dump Pipes $400 Neg & Tomei Expreme Rb26 Manifolds $600 Neg
I would never LS an R32 either. I do have truly evil thoughts about VK56s or the Toyo V12s out of New Zealand though. Very hard to justify for my daily....
Oh no. There's heaps. A whole lot of them are legitimately handling/installation problems. The material used in the L19 bolts is susceptible to hydrogen embrittlement and must be kept well oiled and not handled without gloves, etc etc. There have been many failures of these from people who didn't realise. There may also have been failures caused by conditions inside the engine (say, head gasket failures?) and people didn't realise that that was probably a death warrant. But that's the L19 material. The ARP 2000s are not made of the same stuff and are more forgiving. But from what I gather there have been occasions where the head has pulled off of one, and non-one can say that the installation was at fault (given good torque records), etc etc, but maybe just maybe the face of the rod shoulder where the bolt head sits wasn't actually perfectly square to the bore of the hole...and loaded up the head with a torque across it and.... ping! I've head stories of bolt heads being found in corners of workshops or in the bottom of sumps even without starting and running the engine! Trouble is, it is really hard to sort the true material failures from the handling/installation failures. It's worse than human medicine. You can only run the experiment once, and you can't run it backwards in time to look at the rod before it became a modern sculpture.
By hardsteppa · Posted
In my experience with maxspeed rods, it was not that the ARP rod bolts were "fake" but they are made under licence from ARP, rather than made directly by ARP. Not the same thing and quite likely to have more quality variations, let's be realistic. I haven't had any issues with mine. I daresay look hard enough, there would be some failures of genuine ARP products too though? Even if very few. -
By CanadianGuy · Posted
Haha honestly the thought crossed my mind but skylines are so damn rare here someone would probably hang me 😂 I’ve had a few LS swapped cars (280zx and a foxbody mustang) so trying something a bit different this time -
Not much info in that request..... If you have a VIN you could look up the factory part number here: https://www.amayama.com/en/genuine-catalogs/nissan
