Its hard to believe how big the RB26 engine is until its out of the car. Keep up the great work, will watch this build with interest
That's what I was thinking...some decent weight in it too. Cheers David, I just keep thinking of the end result...
Hopefully she turns out to what I have in my head
Well done man good to see another GTR getting the love it deserves. My engine took me 3 days to remove the first time although 8 hours of that was trying to split the gearbox from the motor (had no idea about the pull type clutch fork lol) But dont worry it gets better everytime you do it. Only took me 5 hours last time although i did cheat a bit and cut out the radiator support and leave the gearbox on.......
Thanks Brodie. Yeah just hope I get it right. Can't wait to get some shots of the motor when it's done, pushing to have it done by year end....
8 hours!! Man you have more patience than me. Really hoping I only have to do this once...and do it right.
what are your plans while the engine is out? rebuild or just a freshen up with new bearings/sump baffles/gaskets etc?
Hey mate. Ahhhh a BIG question.... I will let the photos tell the story...
Once motor is done all will be revealed...stay tuned
Few more goodies to keep things flowing....enjoy
1. HKS drive belts, Sard radiator & billet oil filler cap
2. Near new genuine Nissan 444cc injectors - cleaned and flow tested
3. Ruzic 4wd controller
4. HKS braided brake lines
5. HKS Twin Power ignition enhancer
6. HKS Cirle Earth grounding kit
Really can not wait until all this starts coming together......
Have been planning the engine bay alone in my head for months, not to mention the rest of the other car!!
decent start. you are doing the engine first i take it.
I am northside as well. if you need a hand with it let me know. oem parts are not an issue either if you need a siurce for them.
Cheers Chris. Yep, fully committed to a motor that is as reliable as possible given my budget/resources...
Also, hopefully the engine bay turns out to be the 'work of art' I have had pictured in my head for a long time now!
Yeah will do re OEM parts. I have most things ordered or on their way...
One thing I am struggling with is what to do with front head lights. Not sure which way to go with these? Do you the details on the N1 lights...what's the deal with them?
N1 Headlights - Kudos Motorsports. Best Price :thumbsup:
Cheers Richard. I don't really understand the benefit of the N1 headlights...can anyone provide details?
I just haven't found the time to research this item and whether it's worth spending more $$ on....
some good quality parts mate! keen to see it finished!
keep the updates coming
Cheers Damo. You and me both, really trying not to rush it...still a long way to go but should have motor ready by end of the year
And yes all parts are Japanese and Aussie made quality that will hopefully serve me well!
A couple more additions:
1. Apexi intake kit
2. Koyo Racing R Spec (53mm core)
3. Garage Defend (CF) full length radiator cooling panel
how much?
about $730 for the pair of N1's (Rarer)
new projectors over $1k
N1's
the inner light is the fog light, so the button on the right hand side of your dash will once again work
It probably boils down to prefrence like most things. I'll remove these pics in a few days to clean your thread.
1. Apexi intake kit
what are you looking to get out of the build? power figure
Someone correct me if I'm wrong but don't u have to check all the clearances before ordering bearings???
N1's
ive heard and dont quote me that the projectors give of a better light spray what not. im keen on a set of N1 tho for my car personally
also on a side note is that colour factory? do you have the paint code?
BMW Blue water metalic - Paint code 896.
As you can see I've had both Projector and N1's.
In my experience the N1's have better light which is further improved with a quality set of higher rated Phillips globes.
I'm actually thinking of replacing the fog light globes with a higher rated phillips globe as well to see the result.
Still undecided on the HID's I have in there ATM - they need adjusting down but daylight effect at the moment.
I Can't drive behind friends because they complain, so I have to take lead :P
On builds as many say - Over spec your build and under utilise.
The ones that go bang are those pushed to the limit (often) and/or beyond once !
Did you buy the carbon fibre cooling panal locally or from straight from jap land?
Japan man, really trying to stick with Jap & Aussie made gear
Nope. Running an extra thou clearance as upgrading to Tomei oil pump
Not sure mate, really not focusing on power output...trying my best to achieve reliability (given my budget/resources) as will be doing a decent amount of track work
Ok but how do u know exactly what the clearances are? It was a mass produced motor so each one can be different, I've always seen n been told to measure before ordering as each cylinder can b different
Intake side half stripped down:
Hot side stripped back ready for cleaning
After multiple cleans:
All loaded up for the first of many runs to 'the mechanic's'
So much more cleaning to do....fun fun
Edited by PranK
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
