Hi,
I've been eyeing this forum as guest for a while.
Until I stumbled upon your build in this thread, I am gaining a LOT of information, and made me register to SAU especially to say congratulations on your build. It is really high class and indeed a must-see for all GTR owners.
Cheers and keep them coming.
Regards,
omDidit
  • Like 1
  • 3 months later...
Lakeside Classic - July 26, 2015
None of this build would of been possible without the man sitting next to me. Endless hours spent together talking, planning, working.
Forever thankful Dad.
  • Like 10
  • 1 month later...
  • 4 weeks later...
that sound is so clean, such a smooth note, this 32 redefines what a super car really should be, not a ridiculously expensive prima donna, but more a true almost indestructible super hero, clark kent when your doing the shopping and superman when you need to move faster then a speeding locomotive
  • Like 1
:woot::woot::D:D:D LOL mate this is so good!!! You have a big one last night....?
Always appreciate randomness like this, well done Sir, let me know if you're ever in Bris n we'll go for a run in the hills :thumbsup:
  • Like 2
i followed the the build thread from the beginning and was pumped to see a live action vid, the comment came because about a week before a mate bought a euro sports car and we took it for a thrash in the adelaide hills and a check engine light came on and the car started running like a bag of diseased dicks.
prompting me to ridicule him endlessly as once upon a time i owned a 32 GTR but it was nowhere near your work of art, and i remarked how a true supercar should do everything a car does + some of what a supercar can do.
If i am ever in brissy will drop you a line, planning to move to the big QLD within the next 16 months so the burn will probably consist of me trying to keep up with you in my 33 and failing miserably lol
  • 3 months later...
  • 1 month later...
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
