Omg.. I hope you can do your best to keep it that clean!
You'll notice every little spec haha.
Still a f*cking awesome job.
Thanks Zane. Trust me, I will keep it clean.
More gear back from coating
Rear hubs cleared
Assembled
New OEM Nissan gear
Dude that is looking mint as!!!
No long now by the looks of it.
Cant wait to see it rolling.
When it does you wont be able to wipe the smile off your face.
BRAVO! I have a gun grey R32 in BC Canada and always thought about doing a major as you are! I would have to buy a second GTR for I think I might miss driving it for that long haha. Nice work man! inspiring to say the least!
Cheers bra! Not long at all mate. It has rolled.....it was glorious!
Hey mate. Nice! My brother is living in Kitimatt, BC. Where are you located>? Haha yeah but it would be worth it! You could get a lot done over the 7 or 8 months of snow...?
Thanks again
Fuel pump out, in absolute mint condition!!
Tank cleaned up
Pump in and ready to put back in
Getting throttle pedal to fit up firm, was flopping around prior
Cheers to Ants for the rear window plugs
Hey how thick is your radiator, i am after an aftermarket radiator that supports the factory fan shroud as well. did you have to cut the shroud at all to fit
thanks mate. keep up the awesome build thread :)
Had the same issue with the accelerator Peddle. (R34 race peddle set)
Plus found the length & angle of the new accelerator arm was off for my 32.
So moved the peddle onto the existing arm and firmed it up the same way.
the speed and precision of this build, damn.
thats Robbie for ya.........the man is just ruthless of dedication and had the eye of a tiger.
Well done Robbie
  • Like 1
Well done Robbie
Thanks again
Tank cleaned up
Hey buddy! Ya Kitimatt is 9 hours from Williams Lake where I am presently! moving to Vancouver BC soon so can almost drive the GTR year round! well when its not raining so ya 6 months a year still haha. Maybe I will do a ground up in a year a 2! Thinking I would enjoy it! Thanks again for sharing your labor of love! NOW GET BACK TO WORK! need more pics haha
Coming along nice where did u get that small plug from
Cheers mate. From Ants on here
53mm. Didn't have to modify anything but we did have to use some rubber spacers to raise up the radiator maybe 5mm or so, before doing this the fan was only just fowling on the shroud.
Cheers man
should be put away in a climate controlled environment....too good to drive
Ha can't do it, only live once
Nice
world best skyline build... you can use this to reference parts and help you... make a sticky
Thanks mate!
Thanks Glyn. Insane amount of planning, thousands of hours and knowing the right people!
Well done Robbie
:blush: much appreciated mate, will be good to get the two of them together, give me about 7 weeks!
Man I have got to get a ride in this sometime!
For sure! Let me know when you're in Bris
Wow what a build keep up the good work :yes:
Thanks mate, not waiting on much now!
Exhaust and drive shaft in for good
Terminated the 3in drop down that came on the Apexi catback so she is 3.5in out of front pipe to first muffler then 4in section to final muffler/cannon
Mate, seriously, stop it! Posting those piccies of your "undercarriage" are enough to make any grown man milk his baby wand till it runs dry and drops off!
Everyone is right, you shouldn't drive it! Keep this one in cotton wool then make another one that you can drive!
  • Like 2
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
