Mmmmmm.....nismo carbon rear view cover.
I just love new parts especially oem parts........all this build just does is motivates me to spend more money on my build lol
  • Like 1
The Nismo reear vision cover looks amazing when on. Though i would paint the existing full rear vision mount black as the grey stands out heaps when you put the cover on. Sorry for the image quality, this is mine on:
also anf, I would not paint but just put some 3M carbon scothcprint on that area
Holy crap even better idea. I have some left over from doing my door cards. I know what im doing this weekend!
My thread is coming slowly. Gotta get around to making one. The box has clear on it now. Around 4 coats just to reduce stone chipping.
Gonna grab one of those nismo covers to next order. :)
hey Robbie - what is the last picture of in your last post ?
All the rest I have but bugger me if I can work that last one out mate
Im going to take a guess and think its a number plate bracket right?
Its the fire extinguisher bracket mentioned earlier that mounts at the front of the drivers seat.
Glad we all agree Nismo cover is the business :thumbsup:
So got the adaptors finished off
And this guy in
Hadn't peeled the clear of this yet in photo
Wasn't happy with the way this guy was sticking, got some 3M transfer tape (very thin)
Then this happened Sunday arvo :(
No damage except a tiny nick out of the fan shroud. Yet to find out what the cause was, but have since heard the Ross balancers are a common cause...yet to look into it further
That sucks!
Is it the Ross Metal Jacket Race, or the regular Metal Jacket?
I know that there is a new revision that only comes with under driven pulleys to avoid this problem. Maybe you have the old revision?
Edited by Jazzadub
That sucks!
Fkn oath!
Running the one below. Just metal jacket. Looks like you're spot on Jeremy...
There is another one now listed below on the website, looks like I will have to get onto Ross and see what he can offer
NISSAN 306212 METAL JACKET HARMONIC BALANCER - RB26-R32 20%U/DRIVE P/STEER
Edited by $$slowmedown
Yea that's unfortunate.
You can also get a pulley kit like below which could solve the problem - this is a picture from Ross website.
But yes, I would talk to Ross to see what they recommend.
Edited by Jazzadub
There is also another MJ revision 306202X2 which I'd say is version 2 of yours, which could save you having to go to an underdriven pulley?
Does the P/S pulley look different on this one compared to yours? Could be a better option than an ugly extra pulley?
Edited by Jazzadub
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
