  • 3 weeks later...
0nly badge it needs is on that says "F**K YEAH"
Haha cheers mate, may detract from the look I am after ;)
I take my hat off to you sir...phenomenal effort.
Thanks a million Scott!
Well done on a great build.
Now every other GTR looks filthy compared to this.
Much appreciated Phil, unfortunately bnr32's are well and truly showing their age in most cases. But look what endless hard work and a significant amount of money can achieve!!
So not much has been happening of late. Latest jobs have been on the interior/electronics. Repositioned the defi display to be to view it easier. Also, got it setup properly re speed and rpm display. Input maximum rpm parameter and the shift lights working. Lastly, got warning values input for oil and water temp and oil pressure.
Have finally started looking at ruzic controller install. It will be going in the glovebox with an extension harness so driver can adjust as needed from the drivers seat.
BeeR is going to be mounted as pictured for ease of adjustibility and just looks dumb anywhere else! Wiring will run up into side of centre console
The thought of a Bee*R on this thing makes me sad :(
Whyyy Robbie? :(
Thanks for the input Martin. Have you used a BeeR personally? What were your findings?
Why? RPM control when on track and possible use of the launch control function if it proves to be useful...
Echo sentiment
Your thoughts Richard?
Edited by $$slowmedown
It's your personal choice of how the interior looks and tech gadgets based on what you intend to do with your GTR.
placement for ease of use/vision I understand. Wasn't really my place to comment.
But having already opened my mouth.
- my personal opinion is to keep gadgetry minimal, functional, fit for purpose, base on frequency of use, and out of sight (as much as is possible).
some are done well and some aren't. Bit worried - that is all.
I like the clean interior of the R32 GTR.
  • Like 1
My comment was based on the reputation of the Bee*R limiters to do damage. Whilst I don't have any first hand experience with them, I do understand how they work. And it's not good.
In case you're interested or unaware, the Bee*R limiters work by grounding the coils rather than cutting signal completely. So when you hit the desired RPM, the Bee*R sends PWM pulses to the ground side of the coil and it doesn't fire. However PWM signals aren't just an on/off voltage, they are a pulse with varying duration, and in the case of ignition, the coil pack fires when it reaches the END of the pulse not the start. So when the revs drop below the desired limit again, the Bee*R stops sending the pulses to the ground side, and the coil packs can fire again. But because it has actually delayed the pulse, the spark can now occur at the wrong point in the cycle, and effectively results in detonation the same way advancing your timing too far would. In addition, if the yellow gain knob is set too harshly (which everyone does because the faster it cuts the cooler it sounds), you get a very aggressive accel/decel, which is no good for your oil pump or valvetrain.
I can see why these things were popular when they first came out, as the idea of an ignition cut vs fuel cut sounds much healthier for the engine. However I think it was done the wrong way, and it should be cutting the signal completely via a relay, so that the cut only ever starts as a spark happens and only ever ends as a spark happens, thus cutting the cycle completely. However modern ECU's like Haltech, Link, Adaptronic etc. have all sorted out a way of making fuel cuts quite safe, as they allow a percentage of fuel/ignition to be trimmed before the hard cut, at very very fine intervals.
  • Like 2
  • 4 weeks later...
Cheers for the input guys, appreciated as always.
Have been flat out getting this thing finished off over the last few weeks. Will get an update up asap!!
For now I found these :teehee:
  • Like 6
The detail of this build is ridiculous. I would love to see it in the flesh.
Well done mate congrats! :worship:
Cheers Steven :D
I don't even know what to say any more. I love this car.
Also great pics again
Thanks again mate, hoping to get some professional shots done someday soon!
Starting to forget what has happened over the last few weeks so better get something up or will never happen!
Hopefully one of the last lot Nissan orders came a while ago
New wiper arms with PIAA blades fitted up
Door trims back off to fit up the new interior window trim pieces
And forgot to get the after shot but all pretty boring stuff really, just finishing off the details!
Next up got the new rear quarter glass in (old glass was temp fitted) along with the new door opening trim that screws up to the body (again had to remove the old ones out along with the rubbers, a delicate job!!)
Also removed the Nismo option 3 piece body kit and got it fitted up properly with all new Nissan OEM clips/scrivets/screws etc and some quality 3M VHB double sided tape.
Will get photos up of the finished product just forgot at the time :/
Have also had the car back to paint shop for final detailing, had it corner weighted/wheel alignment done and new window tinting as been done. Will get details up soon...
One of the last things to do is fit up the original badges....can you anyone help me out with this?
I am chasing a car in original paint with ALL original badges so I can put mine side by side and measure up the placement of the badges accurately. Would be greatly appreciated.
Cheers
  • Like 1
Finally popping wheelies lol! Car going onto scales to get a base and see how everything was sitting.
Numbers came out as follows:
TOTAL WEIGHT (with driver 76 kg + approx. 70 L fuel = approx. 54 kg)
3,465 lb = 1,571 kg
CURB WEIGHT (less driver & fuel)
1,441 kg
CORNER WEIGHTS (WITH DRIVER)
LF = 980 lb RF = 1017 lb
LR = 710 lb RR = 757 lb
PERCENTAGES (WITH DRIVER)
FRONT = 57.63 %
REAR = 42.33%
LEFT WEIGHT = 48.77 %
CROSS WEIGHT = 49.84 %
Overall pretty happy with how numbers turned out! These were the numbers as the car sat with no adjustments needed as well.
Would of preferred it was lighter but it is what is now. Happy to hear thoughts on these or even better if you have numbers to compare?!!
Next up was wheel alignment:
All went pretty smoothly. Got it set up for a comfortable street ride that is easy on the tyres.
There was a problem with the front upper arms. More to the point with the brand new Whiteline bush kits for these....
With everything all tightened up there is a noticeable amount of slop in the bushes where the upper arms bolt up to the body. So much so that the camber could not be reliably measured/adjusted.
My mechanic got a chance to pull them off the car yesterday and straight away noticed that the problem is a design fault with the Whiteline bushes, I believe it seems to be the metal pin that sits inside is to short so when tighted up the outer bushes can't 'crush' onto it. Has anyone else experienced this issue?
All the other Whiteline gear has been fine so far...it just seems to be these upper arm bushing kits...
Any feedback/thoughts/experience would be appreciated
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
