Any updates on this beast Robbie?
Not a great deal Amir....
As it would go getting the last few issues/details finished off is taking a massive amount of time. I've been flat out with other things as well as waiting on parts so the R has been spending all its time in the garage :verymad:
The noisy front end has also made driving it very very annoying, which we put down to the spherical bearing front strut tops, so my main goal has been to get this sorted asap.
New ISC tops arrived a fews ago and have only just had a chance to get them swapped out
Forgot to get photos of the coilovers completed with the new tops
Actually took a bit of time and a little modifying of the strut setup given the new tops are a fair amount thicker than the old ones. Again I didn't manage to get any photos, but under the foam stopper there is a tubular spacer that needed to cut 10mm and also used a couple of washers to get the spacing/height right.
There has also been issues with the Whiteline front upper arm bushes but will get into that next time.
Have the new bonnet insulator/clips for ages now and again finally got the time to get it on
  • Like 1
Rear brace going on...FINALLY!!!!!
So it turned out I was the lucky one to find out that Whiteline had manufactured the bushes below out of tolerance, had to wait months for these to come through. Swapped the old ones out and re-installed. Had been been using a spare pair of Nismo UCA's in the mean time.
Got out for a very quick drive to test and all sounds promising....all those annoying front end sounds are gone :D
  • Like 1
Hi Robbie
I'm looking at the ISC strut tops myself, can you please explain a little more about
Thanks
Mark
so envy. much jelouse. wow.
Ha classic Glyn
What Strut Brace is that?
Tein Anthony...they are legit :yes:
Hi Robbie
Thanks
Mark
Hey Mark
The spacer is more relating to the coilover, in my first post on this page, look at the third photo. You will note there is around 40mm of the shaft between the polished section and where the thread starts...
The spacer (tubular) slides over the the shaft and sits on the step where the polished sections begins. It spaces up the strut top onto the thread section...otherwise as you tighten up the top nut you would just be continually tightening and loading up the spring!!
The spacer was approx. 35mm but due the ISC top being thick we cut it down to 25mm and used a couple of washers to get it just right...
In your case, it would all depend on what coilovers your looking to put the ISC tops onto...
Cheers
I was greatly honoured to check this car out today at the r32 gtr anniversary meet, truly remarkable, pristine !! Definitely my favourite car of the day hands down
Congrats mate
  • Like 1
That rear bar, number plate light & the plate itself is some jizzworthy shit.
Mind PMing me specifics on how to set mine up like that myself? Mainly after the frame etc ~
edit: Just checked out Vplates.com.au - is that just a "Prestige" style plate mounted normally?
Edited by Cevzy
Can't wait to see this @ WTAC this year.
:thumbsup:
Congrats mate
Cheers Michael!! Really great to meet you. Didn't even get to check out yours out...
Fkn wish there was more time and the weather wasn't junk. Hopefully we can all get out for a cruise sometime before WTAC in October??
Love this car, it's even better in real life then it is in photos
Thanks heaps Brett, was awesome you got it all together and made it!! Awesome to meet you mate.
So immaculate! Glad I got to see it in real life.
:thanks: Ravi! As above wish we could of all got to cruise together, one day...one day
Lol thanks Joesph. Yep, correct, the number plate frame is just the standard frame supplied from PPQ (personalised plates qld).
You can leave it at my place if you want..... Hell of a car.
When does work start on the next one? :woot:
Hahaha once in a lifetime didn't you know Anthony!? Thanks again mate
Awesome!
Was very happy to see that in person :)
Cheers Chris, appreciate it mate.
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
