  • 4 weeks later...
  • 8 months later...
Had a read through this build, and my jaw just continued to drop further and further the more I read. Well done mate, car looks amazing! Could you please tell me what the carbon radiator panel is and where to get it from? Really tidies up the front when the bonnet is up! Cheers
  • Like 1
On 8/7/2013 at 10:20 AM, $$slowmedown said:
I don't think it's unrealistic either that the bnr32 will appreciate in value over the next decade or 2 or 3...time will tell
and didn't they just.
  • Like 3
  • 4 weeks later...
  • 3 months later...
  • 1 year later...
On 04/05/2017 at 6:34 PM, AMR33 said:
What's happening with this car? Would like to see some updates if there are any....
It gets driven quite a lot Amir....mostly at high rpm, around corners. There has been a lot of changes in the last few years with some big ones of late.
On 16/08/2017 at 2:15 PM, Darmanin10 said:
Spent the morning looking through this thread start to finish.
Insane build, any updates?
Cheers mate, hope it's of some use. Will do my best to go back and get the oldest updates/changes posted up soon. Stay tuned ?
Edited by $$slowmedown
  • Like 1
waiting with anticipation robbie ;)
  • Like 1
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
