You need to differentiate between weight distribution and centre of gravity. The heavy wing helps with weight ditribution but not with the c of g.
Anyway out of interest are N1 rear windows available at all?
Yes, N1 windows are available.
Do you want one? or are you just referring to another method of removing the rear wiper?
Because the costs of the N1 rear window by far exceeds the costs just getting a rubber grommet (although N1 rear windows do look nicer :P )
Edited by Ants
Nah I was just curious. Obviously a rubber grommet is cheaper than a window, not to mention the drug money Nissan want for the rubber sealing strip that goes around it. Probably why I have seen a few GTR's that have suffered from a broken rear window where the owner has full glass coverage on their insurance. Coincidentally. Allegedly. Apparently. From what I heard. On the internet. From overseas. Hmmm.
What I would like is a new windscreen with an antenna in it, rather than the local ones which I understand dont have them.
Activities from the weekend, got the front subframe stripped down ready to start paint prep
Plan is to get everything cleaned down, painted, replace hub seals (bearings feel good), some new ball joints to replace
Also have to get the rotor dust shields off, can anyone offer any advice on doing this easily/best way?
  • Like 1
This is like watching a show of overhaulin, except instead of some random muscle car it's a GTR!!
How the hell did you learn to pull a skyline down into this many components and put it all back together? Did you work at the Nissan factory or something?
I cut my dust shields off yesterday with a 4" grinder and just left little tabs on there.
Cheers mate, appreciate the input
Haha cheers Nick, plenty more to come mate, still going with the shit stuff!
Just learning as I go hey, all about having the right people around you, right tools, a big shed and an old man who is always there to help
Yet to see how it goes putting it back together....that's the hard bit (but the best)
Yep definitely cutting wheel / grinder as Michael said
Thanks for confirming Paul
Took some photos of the bay when the light was a lot better, pretty happy with how it came up
Looked a bit worst for wear that one!
Might be worth cleaning up and putting aside in case you ever change your mind.
What do you have in mind to plug the small squirter hole ?
(an automotive plug from supercheap with silastic might do a good job)
Edit: JJR have the rear C panels for $160?
Rear wiper removal fun...
Easy part
Nut rusted and fused to thread
Hacksaw out
Success, got it with no breakage :banana:
More junk for the bin
Awesome Robbie.
Looks like that nut was really FUBAR. I wonder if mine is going to be like that, if it is at least I will know what to do then :yes:
Kind of perfect timing as I received this in mail.
Will fit perfectly for the rear wiper hole (being 30mm).
For the nozzle hole I have found this of which I have just purchased from
http://www.ebay.com.au/itm/Blanking-Grommet-10mm-Panel-Hole-Pkt-6-/321090727402?pt=AU_Car_Parts_Accessories&hash=item4ac27fadea
We are all sorted :thumbsup:
Edited by Ants
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
