Nismo Lmgt4's Work Xt7's And Rb26 Bits, Gt-R Rotors Etc
Hey guys time to get rid of some bits
2x Nismo LMGT4's 18x9.5 + 18 ( Matt black with bit of gutter rash and crap tyres) $1050
2 x Work XT7's 4 Stud 17x9 + 18 powdercoated black with Toyo R1R tyres 95% tread 235/40/17 $1100
2x Std R32 RB26 turbo's (came off a working car I was told) $100 the pair
2x R34 GT-R STD Stainless Steel dump pipes $200 the pair
1x R33 GT-R Intake Plenum freshly stripped and powdercoated satin black $220.00
Set of GT-R Throttle Bodies $100
Pair of brand new RDA 324mm rotors ( with some surface rust but never used) $200 with a free set of endless brake pads used but lots of meat.
Set of dog bone adapters to use r32/33 caliper on 324mm GTR rotor (80% sure these are for a GTS-T $80.00
BeeR rev limiter $80.00 used
R32 GT-R engine loom in good condition $160.00
Twin turbo pipe in std silver wit elbow for rear turbo in good condition $80.00
HKS VPC ( vain pressure controller) so you can run a map sensor on STD or remapped ECU including harness and remapped ecu $200.00
I am sure there is more but this is a good start
Email me collins.andrew.acATgmail.com
or sms 0434425026
Cheers
Located near baswater vic and can post at buyers expense.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
