So i have for sale a 1989 Gts4 shell, it has widebody GTR rear guards, straight undamaged and uncrashed, It is complied and registrable, previously registered in QLD.
Included in the shell;
Carpet, all windows, handbrake, drivers seat, door cards, steer column, pedal box, roof lining pillars etc, suspension (except coil overs) rear subframe including diff, rear shafts all hubs and arms, tank (no fuel pump) engine bay wiring (excluding engine loom) Brakes lines, steer rack and lines (Has hicas removed) Front and rear subframes, Engine bay is painted black and shell is painted orange with gold fleck. Has still fitted computers (except engine ecu) and also torque split controller so can run rwd or percentage with a switch all fitted.
I do have parts that I am still selling that can be included such as bonnet, brakes, ABS, master cylinder, dash, boot, tail lights rear bar, bolt on flares etc.
EOI around $3000
Contact Johnny 0414596256 or PM
Located on the Gold Coast (North)
Heres a picture when the car was complete, so you have an idea
Looking like I will strip the shell quite bare, will still have windows and most standard arms of suspension, coilovers and brakes will be taken off interior will be quite bare, If anybody is interested it does have great wide body fibreglass rear quarters and is very straight, complied previously registered etc, so if you have crashed your car or want a project hit me up. Price is also dropped to EOI or $1500 ono/neg
Cheers!
Edited by slidinr32gtr
  • 3 months later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
