Ever Fought A Speeding Fine In Victoria? Here's My Day In Court:
Alleged refers to benefit of the doubt factor having being applied to the detected speed, to cover variance in speedometers and calibration of measuring equipment. But yes the actual wording "alleged" is because until someone pays the fine, you're considered innocent. Paying the fine is an admission of guilt.
  • Replies 44
Need to vent.
Keep seeing the ad campaign everywhere "This is why you are photographed when you speed" And it's making me so f*****g angry.
They're either just hypocritical beaurocrats or retarded do gooders. I'm not sure which.
If the only reason we're fined is safety; Police would make their prescense known; Cameras would be painted Hi Vis; and wouldn't be hidden in every dastardly place they can think of. You would be fined on the spot; and not mailed a fine three weeks later as that doesn't deter anyone.
The reason it gets to me so much is because I live here and the fairness of our state is slipping away. It seems to have happened in the last decade.
The majority of people know some of these things it are not right; and yet; it won't be changed. What can you do except vent? And then you get the public transport types talking down to you?
I hate the latest TV campaign trying to tell us how much speed cameras save lives.
So we're now paying to be taught that the things we pay for, to take further money from us, aren't there just to take money from us.
The verdict isn't too bad, I'd call that a win for you.
The judge would normally just throw it out under some rediculous reasoning that police are always correct and your guilty....
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
