  On 24/11/2012 at 6:38 AM, G37Sam said:
You're definitely getting some great deals man.
May I ask where you guys normally install your surge tanks? Another reason I stayed away from it was that many told me you get a lot of fuel smell in cabin?
You shouldn't do as the tank should be shielded from the interior. Do you have room under the car?
Have you had a look at this:
http://aeromotiveinc.com/2010/01/fuel-pumps-and-horsepower/ ?
Great article Bob, thanks for sharing that. Not sure if there's room under my car tbh, and I don't want to start butchering my trunk yet :)
BTW, can in tank fuel pumps be used as exterior ones later on if I want to convert them into a surge tank setup?
Depends on the pump - I know 044s can. If your aeromotive pump was also sold for exterior use it/they should be fine.
My surge tank is in the back of my wagon and a bit of a pain TBH
Its insulated and deosn't smell of petrol but it is noisy and takes uip space:
cover (now insulated and carpeted:
Mate use the Teflon Braided hose and NO fuel smells, Not many current braided rubber hose brands are compatible with current 98 octane fuels. The set up in the pic is single 044 external,800cc Siemans injectors, 4 bar fuel press at idle (no vac hose connected) made 550 AWHP
PS: OEM in tank pump supplies surge tank...
Cheers n good luck... Awesome price on Aeromotive pumps btw, we get shafted on Aeromotive and Magna-Flow stuff in Oz...
Under the car mate. Have a look at Alan's aka 33gtrv's build thread.
  • 6 months later...
Drove on these for a few months, they're working great so far! Small problem though, they starve like crazy! If the tank is anywhere less than 80% full I have to be very conservative with my throttle input. Forget applying any throttle on right handers.
Can one run in-tank pumps externally? Or will they over heat? I'm seriously considering a surge tank setup now.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
