Hi Guys,
Since I lunched 2 pistons on the dyno, I'm up for fresh internals.
I'm not going for anything too crazy: the car was running about 420awhp on N1 turbos, before the rear turbo let go.
Since then, I fitted stainless exhaust manifolds, Greddy inlet kit, Z32 afms and HKS GTSS turbos. It was during tuning this setup that the engine let go. Luckily, the head remained undamaged, and the block is still in good condition. Given the smallish sizeof the new turbos, I'm looking for early spoo-lup, and a nice healthy chunk of midrange torque: outright power isn't a major concern. The car is never tracked (I'm unable to due to medical issues),so is 100% street driven.
I'm looking for advice from those with experience on what brands of piston and rods to use, as there seem to be a million different opinions out there, and I have very little experience/knowledge with built engines/internals. I want to keep costs reasonable, but want something that I can rely on to last.
Any help would be appreciated: I figure some of you guys would have seen a bunch of the good/bad/ugly, and its your advice I'm after!
https://www.sau.com.au/forums/topic/414257-which-pistons-and-rods-to-use-rb26/
For that amount of hp spool rods and cp pistons will b plenty reliable. Not badly priced either! You can get a rebuild kit, see the link
http://www.spoolimports.com/spool-engine-rebuild-kits/nissan-rb26dett-rebuild-kit
If ur chasing big power u can't go past nitto
Edited by GTR260
Cheers guys. I have more questions:
At the 600+HP we're planning, there has been some concern that my N1 oil pump won't be up to the job: is this a realistic concern? I'm happy to replace it, but am trying to keep the rebuild costs reasonable, so limiting unnecessary spending...
Also, at this power level, will the crank need to be nitrided? Once again, this is something that I have heard, but am not sure if it is overkill on a mildly modified engine...
Get some billet oil pump gears and stuff them in the stock housing...sorted.
Stock rods could do with ARP rod bolts and resize the big end and check little end. By the time you add it up you may as well go a set of brand new H beams...
Crank is nitrided from factory so is usually good to go as is, just check, grubscrew and balance.
Built Sloane's 32GTRB26 with CP pistons and nitto h beams, puts out 370RWKW and will take more :D
My 32GTR I had built: ACL forgies and spool H beams, just pick your bits and go!!!
I have very good experience with Wiseco, that I used in two RB26 engines. I don't recommend Cosworth, had two sets, and both sets had issue with cracking rings.
Edited by DaanGTR
Cheers guys: looks like it cp pistons, and probably spool rods, arp bearings and studs, 1.5mm oil restrictor, then slap it all together, and hope it doesn't grenade on the dyno this time...
Seriously though, thanks to all for your valuable advice: very much appreciated. I'll let you all know how it goes once its built and tuned...
I've heard some of the chinese made rods also need checking/finishing as the tolerances can be a bit sloppy. Does that sound right?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
