cleaning out the shed and selling off 33 parts. loads of them with multiples in some cases. some aftermarket, lots of stock bits, some gtr and heaps of gtst. Some fit both.
All parts are in excellent condition unless otherwise stated.
Payment is by cash on pickup or postal money order only
NO BANK TRANSFER OR PAYPAL
Parts are located in Ipswich qld
Happy to post most items at buyers expense
cONTACT VIA PM OR PH. 0413863207
Pic 1.
rb starter motor...$80.00
Rb alternator..$75,00
Rb 25 a/c compressor...$100,00
Rb 25 Power steering pump...$100.00
Pic 2
Wiper motor. $30.00
gtst clutch master.$35.00
gtst clutch slave $30.00
a/c mounting bracket $20.00
Cas $75.00
Aic valve.$40.00
02 sensor $20.00
pic 3
Rb clutch fans, no cracks, uncut. tight clutch's $75.00 each
Rb25 g/box sandwich plates $30.00 each
pic 4
fuse box covers. $10.00 each
33 gtr front abs sensors $20 dollars
pic 5
Series 1 engine loom complete with ecu. $150.00
Series 1 coil pack loom with ignitor $100.00
continued in next post
https://www.sau.com.au/forums/topic/414288-mega-33-shed-clearout/
pic 6
Generic washer bottle with pump and mounting brackets.$25.00
Knock sensor loom with sensors and plugs $50.00
pic 7
Polished 25 tappet covers with all dash fitting and chrome timing case cover $150.00
pic 8
Brakequip braided brake lines for 33 gtst. ADR approved. $100.00
Pic 9
Genuine k&N pod filter $35.00
Washer catch can combo $75.00
Pic 10
Surge tank setup complete ready to bolt to a 33. 044 external, walbro internal wired up with realay and all lines, save a bundle $350.00
MORE IN NEXT POST
PIC 11
33 GTST manual radiator vgc apart from a few bent fins $50.00
pic 12
33 gtst Airbox with near new filter $50.00
33 gtr nismo slave cylinder $75.00
p/s reservoir $30.00
33gtr ABS unit $150.00
twin turbo pipe with logo $50.00
pic 14
GTST tailshaft complete with centre bearing $100,00
GTST rear drive shafts (3 sets) $75.00 a set
32/33 gtr front drive shaft $75.00
pic 15
rear hub sets complete with handbrake cables great for 5 stud conversions (2 sets) $200.00 a set
MORE IN NEXT POST
PIC 16
33 gtr rear sway bar complete $50.00
33 front strut brace $75.00
pic 17
33 gtst front lower control arms, Mint $100.00
pic 18
plenty of window motors drivers and passenger side $100.00 with reg $75.00 without
pic 19
33 antennas (2 of) $50,00 each
drivers side window control box (2 of) $75.00 each
33 gtr g sensor. indicator is red but sensor still works (make a fair offer)
MORE IN NEXT POST
pic 20
Stalk assemblies for series 1 and 1.5 $30.00 each
pic 21
33 surrounds one has the crap rubbed off it for a neat plastic finish the other came from a 33 gtr $75.00 each
driver side window switches (need to know the number of pins on the back) $100.00 each
pic 22
Dash cluster $100.00
climate control unit $75.00
centre console $40.00
all other parts in pic $15.00 each
pic 23
Gtst key set complete with ignition, 2 doors and boot $100.00
Gtr ignition set complete minus passenger door includes genuine gtr key $100.00
pic 24
Mint 33 carpet $100.00
pic 25
uncut unmolested 33 gtst series 1 front reo $150.00
gtst bonnet latch $20.00
MORE IN NEXT POST
PIC 25
## GTST DASH SURROUND RUBBED BACK TO BLACK PLASTIC $75.00
33 GTR DASH SURROUND (SAME AS GTST) $75.00
pic 26
33 rear garnish one clear one black with silver highlght $30.00 each
pic 27
33 gtr (gtst) rear bar in good nick, $75.00
Genuine 33 gtr 2 piece sideskirts $125.00
pic 28
Genuine 33 gtr rear wing with carbon gtr end caps $250.00
Pic 29
Genuine Autec rear wing for 33 with brake laight $150.00
MORE IN NEXT POST
Pic 30
nismo f/glass front bar with blinkers, slot for tow strap and carbon canards. $150.00
pic 31
HKS stainless cat back with gutted cat used but in really good nick 2 reonators. $250.00
pic 32
33 gtst cat back with near new metal cat and hks canon in good condition $200.00
pic 33
genuine 33 gtst side skirts in good condition the usual scratches etc but overall very good. $125.00
THATS ALL FOLKS, Happy hunting
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
