Just thought Id let you guys know.. Today I had my exhaust off and noticed all this stuff blocking my cat converter, luckily I managed to poke it all out with a screwdriver.
It looked a bit like honey comb and Im sure it wouldnt be good for exhaust flow. Just thought Id give fellow SAU members the heads up, I guess you need to check these things!
https://www.sau.com.au/forums/topic/414333-cat-converter-maintainance/
That is what the Cat Convertor is - a honeycomb that acts as the catalyst...
So you've effectively "gutted" your CAT by the sound of it, so it's not no longer a CAT - It's just a piece of pipe...
I really hope this is some kinda joke...
Whoops!
Words like, "poke", "stuff", "screwdriver", "maintenance", "pipe", "flow", "blocking" are about to...
prompt response words like...
"illegal", "rofl", "crazy", "defect", "rich", "knucklehead" as well as "whoops"
Now that I've got my breath back, can I ask you if you've been running rich? And I mean really, really rich?
A little bit of knowledge - or in the case, no knowledge - is a dangerous thing.
The honeycomb is supposed to be there - it's the catalyst that does the job of converting - hence the name "catalytic converter" - the noxious exhaust gases (NOx, SOx, etc) into more environmentally friendly compounds.
How did you think the honeycomb got there if it was not meant to be there? It doesn't exactly look like your regular carbon build up...
A bee went up through my exhaust and formed a colony, so I've been told :yes:
Tis summer, and the Metallic European Wasps are out.
Beware that your replacement metal catalytic converter doesn't arrive with the honeycomb wasp nest inside - that sort of 'blockage' is harder to remove before instal!!
jk
dont know about maintenance as such but ive read that you dont expose the cat to unburnt fuel, leaded fuel, overheating (can melt the substrate)coolant and probably heaps of other things i cant remember, all the above can lead to a blocked or collapsed cat
Also big screwdrivers and too much poking
ha ha! yeah, there is heaps of aftermerket hi flow cats on the market that its not worth the agro if you are caught with a gutted cat
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
