was thinking of getting back into wow.
anyone playing it atm i stopped after lich king start of cata, so got some catching up to do.
i got bored real quick of cata is panda any better or kinda the same.
https://www.sau.com.au/forums/topic/414356-wow-mists-of-pandaria/
They have done a fairly significant update of the graphics which I'd love to play, but for fear of divorce, I shall not activate my WoW account ever again.
WoW is still the game upon which all other games are benchmarked.
Don't do it its a trap. It will be blizzards usual. Same shit different smell. They broke the game when they introduced new classes and they couldn't balance it properly. PVP is ruled by the same classes, and PVE is just recycled fights with a new shell. I used to be a rank 1 gladiator (Priest) after all the changes i could make the top 50 and that's about it for aussie net lol. Also fear of divorce, i know your feel bro.
yeah see MoP was.. just like cata... an Wotlk... boring an just more aimed at the younger generation of people who cry over a game thats to hard an nerf everything so its way to easy then people just cry about it being to easy.. a never ending circle.... being a WoW player from the very launch.. i would say that wow has become so shit over the last few years (tbc was good).. leveling to 90 was great fun... lots of little new things an stuff to do.. but seriously get to 90.. an its all the same.. farm heroics (that you can just faceroll through with little or no atention at all) an then Lfr until you pug normal/H raids... same shit.. new level.. gayer looking armor... not worth it. just my 2 cents
  • 7 months later...
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
