Recently picked up a set of LMGT4s from n15m0 and looking to respray them to black with bare lip. whats the best way of removing ALL of the paint and respraying it to black? I'm not too keen on sanding since I'd like to preserve the diamond cut lip.
I also heard sandblasting or powder coating will weaken the wheels strength.
https://www.sau.com.au/forums/topic/414359-diy-wheel-respray-tips-please/
+1 mask the lips.
I've done this a couple of times on different set of rims, and it's time consuming if you want to get it right lol.
Basically sanded > primed > base coat > clear coat. Turned out schmick but if I had to do it again, I'd just get it powder coated lol.. though I'm a lazy fuark
there appears to be some kind of fungi growth underneath the clear coat. need to scrub that off somehow.
Are you positive it is under clear?
I suggest you try autosol metal polish either by hand or with a mothers powerball attached to a drill.
Hopefully you are surprised with the results.
  • 1 month later...
  • 1 month later...
From my experience of painting my own rims, preparation is the key
Just keep sanding the paint back until you get it real nice and smooth, you only need to take the clear coat off because paint best sticks to paint, or if youve got scuff marks sand it right back to the primer and use filler primer to get it nice and smooth again, then paint, then clear coat.
I got a real nice Gloss black on mine for all 4 rims cost under $40
Mate if scuffs are minimal:
P600 grit wet and dry for sanding back paint, then
P1200 grit wet and dry sand paper for super fine finish
And as Kyle said, preparation is the real key for painting as spray painting is usually the easy and exciting bit.
Edited by Ants
use a nice soft sandpaper, Just enough to add little scratches for the primer to stick on, 2 coats of primer then paint then with a few coats, Depending on the finish use a clear coat or a shiny clear coat
Mine came out looking good for under $50, Though powder coating is much much preferred. Contact Craved coatings
  • 4 months later...
maybe a bit old but powder coating will weaken your wheels. Especially if the temp is above 305 degrees your likely to change the crystals of the metal and create stress concentrators. When done in factory its fine because they test the wheels and have much more control.Not worth risking to your expensive wheels.
  • 4 weeks later...
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
