Recently picked up a set of LMGT4s from n15m0 and looking to respray them to black with bare lip. whats the best way of removing ALL of the paint and respraying it to black? I'm not too keen on sanding since I'd like to preserve the diamond cut lip.
I also heard sandblasting or powder coating will weaken the wheels strength.
https://www.sau.com.au/forums/topic/414359-diy-wheel-respray-tips-please/
+1 mask the lips.
I've done this a couple of times on different set of rims, and it's time consuming if you want to get it right lol.
Basically sanded > primed > base coat > clear coat. Turned out schmick but if I had to do it again, I'd just get it powder coated lol.. though I'm a lazy fuark
there appears to be some kind of fungi growth underneath the clear coat. need to scrub that off somehow.
Are you positive it is under clear?
I suggest you try autosol metal polish either by hand or with a mothers powerball attached to a drill.
Hopefully you are surprised with the results.
  • 1 month later...
  • 1 month later...
From my experience of painting my own rims, preparation is the key
Just keep sanding the paint back until you get it real nice and smooth, you only need to take the clear coat off because paint best sticks to paint, or if youve got scuff marks sand it right back to the primer and use filler primer to get it nice and smooth again, then paint, then clear coat.
I got a real nice Gloss black on mine for all 4 rims cost under $40
Mate if scuffs are minimal:
P600 grit wet and dry for sanding back paint, then
P1200 grit wet and dry sand paper for super fine finish
And as Kyle said, preparation is the real key for painting as spray painting is usually the easy and exciting bit.
Edited by Ants
use a nice soft sandpaper, Just enough to add little scratches for the primer to stick on, 2 coats of primer then paint then with a few coats, Depending on the finish use a clear coat or a shiny clear coat
Mine came out looking good for under $50, Though powder coating is much much preferred. Contact Craved coatings
  • 4 months later...
maybe a bit old but powder coating will weaken your wheels. Especially if the temp is above 305 degrees your likely to change the crystals of the metal and create stress concentrators. When done in factory its fine because they test the wheels and have much more control.Not worth risking to your expensive wheels.
  • 4 weeks later...
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
