Try initialising and loading only afm curve ignition and injection maps. Input injector size etc manually. Ignition vs tps is definitely updated
Have tried this :(Have sent apexi a log now so see what they come back with
Minor update, still waiting to hear back from Apexi
Put another CAS on and it seemed to help slightly, but the problem is still there. I think I'm going to check the wiring for resistance when I can grab a multimeter. Dont really know what else to try at this point
Microtech :D
Eh, after thinking I'd sorted the issue and re-wiring the ignition and re-running an earth for the CAS/wtr temp sesors etc then having it still play up I'm pretty over it now lol. Need to try and find an apexi dealer thats willing to do a swap to test if it is indeed just faulty hardware/programming
The old one is old but, that was the point of the new one lol. Apart from the problem I'm having with the new one, it runs alot nicer with it and has less knock. The old one I've noticed now is alot more slower to respond to changes (e.g. it still says I'm doing 3km/h till I've been stationary for about 3 seconds lol)
I need to find another 33 to see if it does it on that. If so then I know its a unit problem..... or 33's have a really sensitive problem with new power FC's
O.K I need some advice with this from the people who know the Power FC inside out
I have tested it on another R33, which was basically stock standard. Did data init, started it, turned off (Skipping the idle learn, as it was a once only drive) and went for a drive. Performed the same way, dropped IGN around 10 degrees after closed throttle and jumped back to normal 1-2 seconds afterwards
I've been in contact with the company it was purchased from new and got told that basically it isn't covered under warranty becasue I am not the original buyer, fair enough. They said I can send it back to Apexi Japan and they will look at it but may not admit there is a fault with it etc and I will have to pay for postage and I'm guessing repairs also
So its a big risk to take for what could be no gain, I could end up spending a couple of hundred dollars
So seen as it seems to be a fault with the unit itself, Is it likely that it is something simple like a dry/bad solder join that has a poor circuit or something repairable locally by someone who deals with Power FC repairs? Because if it is likely to be something like that I would rather send it somewhere in Australia for someone to look at, Because I think theres a better chance that something will be reported to me and fixed, and it will happen alot quicker
So what do people think? I'm not sure who does repairs on Power FC's but I know there is someone who does (Perhaps it was one of the bigger tuning companies)
Any help would be appreciated, because at the moment It's looking a bit like I've wasted my money
Just found this on the Greenline website in the notes for Power FC:
"When used on 93/8~95/1 models, A/F voltage1~4 needs to be increased 6% (In supplied map)"
Would this make any difference? I'm using a Z32 AFM BTW
Also If i were to adjust these, is it done in the Air flow section of FC-Edit (Where the different type of AFM's are) or the Air flow Curve section? I dont know if this would make any difference to the timing problem but better off asking in case its something this simple
Edited by 89CAL
  • 1 month later...
Thread Revival, David at DMS (FC-Hako) has had a play with it and couldnt find any problems. But I had a bit of an idea today, one for the likes of STATUS and other smart people on here that have dealt with the V7 Power FC.
My Neuatral switch has never worked on the sensor SW screen. It seems to be seperate to the Ntr switch for the start circuit (they use the same switch on the gearbox but looks like they split in the engine bay) so just wondering if the ECU thinks its always in Neutral, could this be causing my issues?
The NTR circle on my Sensor SW check is empty, I assumed this meant that the car was not in neutral but not so sure now
from memory VCT never operates if NTR doesnt work
easy way to test it
clutch in
start car
keep clutch in
move into gear
keep clutch in
rev engine to around 1500rpm
keep clutch in
under ETC, SENSOR SW CHECK you should see VCT turn on at some point past 1300rpm i think
if you never see VCT turn on, its not running VCT, or VCT is never engaging
worth checking
VCT definently works, even in neutral. So neutral swith off on Power FC would be 'car not in neutral' so there goes that idea I guess :(
I know the neutral switches usually stuff up (or the wiring not sure) so was a bit of an idea but looks like another dead end
I'm pretty much out of ideas now. I can go ahead and buy another Power FC and if it works fine I know its the unit I have at the moment, but then I'm stuck with a dead unit. On the other hand if I buy another one and it does the same I know I have 2 working units and can sell one off, no real loss but I'm stuck with a Power FC that has a horrible flat spot that I cant find the root cause of.
Would be really nice if someone had a V7 Power FC I could borrow but its alot to ask someone lol
Unless anyone has any ideas? Not sure what I'm going to do now
Well.... that might not necessarily work. I have a Power FC already (Old Version 2.20E) which works fine. This is half the reason why I think the new one is faulty, but at the same time who knows what they have done with the program, might be more sensitve to something in the new one when compared to the old one.
I've got one more thing to try tomorrow (Which I dont think will work) and then I think I will just bite the bullet and get a new one. Disappointing but I need to have some answers.
It's crossed my mind many times, But I'm set up to tune the Power FC and I like having the hand controller.
Was considering a link, but I've been pretty happy with the old Power FC, and the new one is great apart from this timing issue
for 10 bucks chuck in a a new neutral switch. I have had some issues with idle stutters on decel with both nistune and pfc that look for neutral on decel to initiate certain idle control strategies.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
