FS-located at Everton Park, Brisbane
S2/gtt 2000 OEM turbo, noisy when removed, suit rebuild/high flow $90
S2 automatic instrument cluster $40
S2 climate control unit $40
RB starter motor $30
Set 6 spark plugs http://www.briskusa....tment/dor14lgs/ equiv to ngk 7 heat range. Run in friends car for a couple of days only. $30
SPAL thermofan $40 (http://www.spal-usa...._16_paddle.html
SPAL PWM V3 thermofan controller $40 - ($60 for fan and controller, both used for approx 6 months)
Bob, around 8kg, so auspost quotes around $90 for basic airmail. Know anyone in Brisbane travelling to NZ ?
No - one of my workmates is now driving trucks in Perth FIFO - comes home regularly but not via Brisbane!
I'm pretty sure all S2 Have the bigger exhaust housing. I believe they have Garrett on them rather than Nissan but not 100% on that.
Airmail price should be fine - will just contact guy who needs it to sort out payment - will PayPal be OK?
paypal is good.
Sorry to stufff you around but intended recipient of your turbo has (after searching fruitlessly for some time for an R34 turbo) managed to source one locally. Thanks anyway.
Do you still have the climate control unit or did infiltrator buy it?
Any chance you have the frame / mounting bracket for the climate control unit head unit area for sale?
Climate Control sold sorry. I do have this bracket, I bought this to do the xanavi-out conversion, but never sized it up, so not 100% sure which model its from. Basically 3 models, normal, xanavi and S2 manual. Pm me if interested.
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
