was expecting them to have folded by now
when was the last time anyone was seen using one (apart from, very overtly, Lewis in those promo pics)
Guess you haven't been following tech news?
They're trying to come back and investing heaps into their new phone(Has been a long time coming) which was just released in the UK, I believe.
With the current fall of apple, companies are trying to steal "back" the share of the market that was lost to apple in the first place.
I agree with the gold comment earlier.
I've never liked it.
Nico Rosberg says he had a "good feeling" about his W04 right up until an electrical problem caused the car to stop.
Driving Mercedes' new car on the very first day of pre-season testing, Rosberg's running came to an end in a fiery manner after just 11 laps.
The German came to a halt out on track during the morning's session with unburnt fuel in the exhausts igniting resulting in flames briefly licking the rear right of the car.
With a fault in a wiring loom deemed to be the cause, Mercedes called it quits for the day in order to make the necessary repairs.
But despite only having a brief run on Tuesday, Rosberg is feeling positive about his new challenger.
"At the start of winter testing, you often encounter small issues because the car you're running is a brand new design," said the German.
"We had an electrical problem this morning and, once we had found the root cause, chose to modify the parts to make sure it didn't happen again.
"Of course, at this time of year all you want to do is spend time in the car and get a feeling for how it's working, but these hiccups are just part of the game.
"During the laps I completed this morning, I had a good feeling with the car and it felt solid."
http://www.planetf1.com/driver/18227/8473958/Rosberg-downplays-electrical-glitch
Unofficial Times
01 Button McLaren 1:18.861 37 laps
02 Webber Red Bull 1:19.709 +0.848 73 laps
03 Grosjean Lotus 1:19.796 +0.935 54 laps
04 di Resta Force India 1:20.343 +1.482 89 laps
05 Ricciardo Toro Rosso 1:20.401 +1.540 70 laps
06 Massa Ferrari 1:20.536 +1.675 64 laps
07 Hulkenberg Sauber 1:20.699 +1.838 79 laps
08 Rosberg Mercedes 1:20.846 +1.985 11 laps
09 Maldonado Williams 1:20.864 +2.003 84 laps
10 vd Garde Caterham 1:21.915 +3.054 64 laps
11 Chilton Marussia 1:24.176 +5.315 29 laps
http://www.planetf1.com/news/3213/8473896/Button-Quickest-While-Rosberg-s-On-Fire
Toro Rosso are looking to change to Renault engines in 2014 in order to take advantage of their relationship with Red Bull.
At present reigning World Champions Red Bull use Renault engines while Toro Rosso, the junior team, are powered by Ferrari.
However, the Faenza-based squad is keen to swap suppliers, which would allow them to incorporate Red Bull's gearbox into their own car.
"We are in negotiations with Renault and then we will see. No contract has been signed so far," said team boss Franz Tost. "This for sure would be an advantage because if you are racing with a Renault engine we would have the same gearbox as Red Bull, because this is possible from the regulation side.
"We will use the synergies that the regulations will allow us to do."
http://www.planetf1.com/driver/18227/8473356/Toro-Rosso-want-Renault-power
Bernie Ecclestone has ruled out adding a 20th venue to this year's calendar, saying it is too late in the day.
http://www.planetf1.com/driver/18227/8473109/Bernie-No-20th-grand-prix
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
