Robert Kubica will make his return to competitive racing later this month after it was confirmed he will race in the WRC2 category of the World Rally Championship.
The FIA has given Citroen permission to use a paddle-shift gearbox on the left side of the steering wheel, with its change of speed to match that of a conventional gearbox.
http://www.planetf1.com/driver/18227/8542021/Kubica-to-race-in-WRC2
Formula One supremo Bernie Ecclestone believes a 22-race calendar is within the realms of possibility and is also eager to have stopover in Cape Town.
http://www.planetf1.com/driver/18227/8541693/Bernie-eyeing-22-races-and-Cape-Town
Drug testers have swooped on the homes of several Formula One drivers, including Australia's Daniel Ricciardo, in surprise early morning raids.
Ferrari's dual world champion Fernando Alonso said the testers, from the World Anti-Doping Agency (WADA), arrived at his house at 6.42am on Tuesday.
New McLaren driver Sergio Perez confirmed he had endured a very early morning wake-up call as the result of a surprise urine test.
And Torro Rosso racer Ricciardo tweeted that he "Got drug tested early hours this morning."
He said: "All of a sudden pissing in your own home becomes difficult with someone staring over your shoulder."
Drug testing in F1 is relatively rare, but it is not the first time officials have made surprise visits to drivers' homes.
In 2009 Mercedes driver Nico Rosberg - then with Williams F1 - was drug-tested by WADA while on holiday in Ibiza.
He said the agent woke him up at 7am one morning, informing him that he had been selected for a random drugs spot-check.
"My girlfriend took the call," Rosberg said. "So it was lucky that the test took place at all because she doesn't like being woken up early while on holiday."
Mark Webber recently called on Formula One's governing body, the FIA, to step up its drug testing, after a motorcycle racer was banned.
Former MotoGP rider Anthony West, who now races in the second-tier Moto2 category, was banned for a month after testing positive for the stimulant Methylhexaneamine.
Webber welcomed motorcycling's push to ensure the sport is drug-free, and called on the FIA to become more active on the issue.
"I've always been championing the idea to do more of it, but the FIA have never really been that strong on it," Webber said.
"The other drivers have never been super strong on it, so it's never really been a huge issue."
Domestically, V8 Supercar drivers will be drug tested up to three times more often under tougher anti-doping rules to be implemented by motor sport authorities, according to a Fairfax report.
Through CAMS, V8 Supercars complies with the anti-doping requirements of WADA and the Australian Sports Anti-Doping Authority.
Racing drivers have not been implicated in the recent Australian Crime Commission's investigation into drugs and corruption in sport but CAMS will review its approach to anti-doping, illicit drugs and also race fixing and corruption.
http://wwos.ninemsn.com.au/article.aspx?id=8621883
So for any of u guys who want to
Go or are on thursday. I have a spare silver gp advantage ticket.... Eg early entry, breaky and a pit walk thing!
If you want to join me and a mate for the tour and breaky let me know
$60 0400099986 to tee it up!
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
