Daniel Ricciardo is the Toro Rosso driver leading the race to step up to Red Bull next season, according to his team boss Franz Tost.
Earlier this month, Red Bull advisor Helmut Marko gave his support to Ricciardo, saying he is the "better" driver to replace Mark Webber should the 36-year-old leave at the end of this season.
Ricciardo has proven to be Toro Rosso's best driver in the opening stint of this year's Championship, scoring seven points to Jean-Eric Vergne's one.
Added to that, the 23-year-old has also outqualified his team-mate four out of five times while also securing the team's only top-ten grid position of the campaign.
"Well, performance is all that matters and you definitely can see that Daniel with 11 races more under his belt - which is more than half of a season - is probably in a better situation," Tost told the official F1 website.
"Right now he has the upper hand, which we have seen in Barcelona. But that is a snapshot right now. Generally I would say that both would fit into the Red Bull concept."
However, the team boss has mixed feelings about whether either driver is ready for the job.
"At the moment I would answer with a 'yes and no'.
"Both would have to demonstrate an exceptionally good second half of the season, because don't forget we are speaking about the World Champions, so the requirement profile is quite different to being with a team like Toro Rosso.
"But don't get me wrong, both are on a very good path and everything will depend on the next couple of months as to whether one of the two of them - should the need be there - qualify for Red Bull Racing."
http://www.planetf1.com/driver/18227/8715788/Tost-Ricciardo-topping-the-list
more good news!
New twin turbo v6 NSX sounds a bit cooler. Actually having said that, wasnt there a new NSX in the works with electric front drive and mechanical rear drive? What ever happened to that? Lol
coming 2015!
Honda could supply a second or even a third team when they return to Formula One in 2015 as their deal with McLaren is "not exclusive".
http://www.planetf1.com/driver/18227/8717061/-McLaren-Honda-deal-is-not-exclusive-
http://www.autosport.com/news/report.php/id/107462
I was thinking something more tacky, maybe something like a Carla Zampatti Laser.
So we've had the Williams-Renault / Senna revival
Now Martin needs to get Bruno's management on the phone sharpish so we can have the McLaren-Honda / Senna re-up for twenny-fifteen...
you want them to lose that badly?
:rolleyes:
I don't think it will be "crank it up" in the old 80s sense of the turbo cars. I don't know the details, but I suspect boost will be static, leaving ignition and fuel mapping to be tinkered. Pretty much like the cars of today, plus theres that bigger percentage of power delivered by kers.
Dead right but, they won't be throwing fuel out the exhaust just cause fans want it.
The only limit on the new engines is basically fuel. They are only allowed to carry a certain amount of fuel and it means they will have to be pretty conservative with boost and power if they want to make it to the end of the race. Hopefully they will hot them up to serious power then turn them down for economy but at points of the race lean on it for more power and speed...strategies will be interesting
So they are regulated to 15000rpm, and a specific fuel flow rate for 2014.
Whoever makes the most efficient engine that can run the most air for the specific amount of fuel wins. Lots of lean burn work going on I guess.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
