  On 18/10/2013 at 11:00 PM, sh@un said:
well at least you'll be able to hear Ted when they cut to him in pit lane
New V6 engines:
1 Pro
257 Cons
:P
But seriously...... they just don't have the that wail that the V8s had. Hopefully they sound better in real life
+1 for wanting Maldonado to leave Williams. They arent going to get any more sponsership by having a driver who is hopeless. They need a talented driver to impress the sponsers and bring more money to the team. Bottas was absoloutly outshining Maldonado at the start of the year. Not sure what happened there
I can't stand the V8 engines they currently have. Well.. not quite.. I'll tolerate them but they don't do much for me.
The V10's on the other hand.. they gave me an eargasm. Never saw a race with V12's but I would probably cream myself.
Turbo + wastegate should sound good.
Correct, on next years engines there are two Motor/Generator Units (MGU). These MGU's are the primary KERS now called MGU-K, and the secondary ERS called MGU-H, the MGU-H is designed to recover lost energy from the exhaust heat (hence the -H in the name) by driving a generator unit connected to the turbine shaft. Depending on how much energy is recovered from the exhaust heat, the turbo's airflow will be modulated in accordance to the engines requirements, this motor will also be used to drive the turbine at low exhaust gas velocities, thereby removing any inherent throttle lag with the system.
  • Like 1
The grandson of Australian motorsport great Sir Jack Brabham has secured himself a drive in the support category for the IndyCar championship in the United States.
Matthew Brabham was confirmed on Sunday as the pilot of the Andretti Autosport entry for next year's Indy Lights 2014, following his dominant win in this year's Pro Mazda Championship.
Brabham earned the right to move up to the Indy Lights championship after winning the Pro Mazda title in emphatic style, claiming 13 race wins from 16 starts.
It means the 19-year-old is just one step away from joining compatriots Will Power and Ryan Briscoe in America's premier open-wheel motorsports championship.
Advertisement
"I'm really excited to be moving into Indy Lights next year," Brabham said.
"I remember seeing the Indy Lights cars for the first time in St Petersburg when I was racing USF2000 there last year. I was blown away by how quick they were and how cool they sounded.
"It's going to be a fun year, and I'm very pleased to be on board with Andretti Autosport for a second year."
this is what i cbf writing. :)
this is why I love tech
and it will eventually filter down to us consumers
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
